EPB decided to not disengage this morning.
Restarted the car and it released ok.
I have the following fault codes against the controller:
Just wondering if anyone else has had a similar fault and could confirm that simply replacing the control module resolved it?
Thanks
Code:
Address 53: Parking Brake Labels: 5N0-907-801.clb
Control Module Part Number: 3C8 907 801 A HW: 3C8 907 801 A
Component and/or Version: J540 EPB3 VW-10498 0003
Software Coding: 0000057
Work Shop Code: WSC 05311 000 00000
VCID: 28540A039BFA477E16-807C
5 Faults Found:
03200 - Switch for Electric Parking Brake (E538)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00111100
Fault Priority: 1
Fault Frequency: 3
Reset counter: 109
Mileage: 84789 km
Time Indication: 0
Date: 2009.14.03
Time: 14:40:09
Freeze Frame:
Voltage: 12.30 V
Count: 10
Speed: 0.0 km/h
Hex Value: 0x12E1
Hex Value: 0x0001
Hex Value: 0x1010
02432 - Supply Voltage for Left Parking Brake Motor (V282)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 109
Mileage: 85073 km
Time Indication: 0
Date: 2009.14.12
Time: 08:28:58
Freeze Frame:
Voltage: 13.50 V
Count: 30
Speed: 0.0 km/h
Hex Value: 0x1271
Hex Value: 0x0001
Hex Value: 0x1010
02433 - Supply Voltage for Right Parking Brake Motor (V283)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 109
Mileage: 85073 km
Time Indication: 0
Date: 2009.14.12
Time: 08:28:58
Freeze Frame:
Voltage: 13.50 V
Count: 31
Speed: 0.0 km/h
Hex Value: 0x1271
Hex Value: 0x0001
Hex Value: 0x1010
16366 - Control Module - Internal Malfunction; CPU 2
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 109
Mileage: 85073 km
Time Indication: 0
Date: 2009.14.12
Time: 08:28:58
Freeze Frame:
Voltage: 13.50 V
Count: 41
Speed: 0.0 km/h
Hex Value: 0x1271
Hex Value: 0x0001
Hex Value: 0x1010
16352 - Control Module - Electrical Error
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 109
Mileage: 85073 km
Time Indication: 0
Date: 2009.14.12
Time: 08:28:37
Freeze Frame:
Voltage: 13.60 V
Count: 42
Speed: 0.0 km/h
Hex Value: 0x12F1
Hex Value: 0x0001
Hex Value: 0x1010
Thanks
