2007 TDI 103kw wagon, almost 103,000km.    Was planning to keep this for a while longer at it has still only done relatively low km, everything still works 100%, has zero rattles, nothing is falling off or broken and still drives extremely well, apart from feeling a bit "floaty" which I assume is the shocks.   Have had zero issues with the DSG and still shifts as smooth as silk.
However after recent incident with no. 1 injector failing again and taking out the wiring loom again which cost approx $1,800 to fix I am doubting it's longer term longevity.
Might give it one more chance and see how I go, after recent service / inspection no issues were found apart from a very small oil leak at the back of the turbo which is a seal which is easy to get to.
Only other issue I am worried about is the air con takes a while to cool the car down if parked outside on hot days.
Timing belt and water pump have already been done at last major service.
Is it a ticking time bomb or should I give the old girl another chance?. I catch the train / bus to work do it is not doing that many km's either.
 if i had pd engine, i would change
 if i had pd engine, i would change happy man...
 happy man...
