Hello,
I have the following problem with the Sign Assist and RNS510 on an Passat Alltrack 2013 Germany version.
When the map (Europe East v13) is installed, the Sign Assist is not working. When I delete the map, sign assist is working.
Some background info
I upgraded the original firmware (4020) to 5238 josi version. The installed map is Europe East v13 version. Previously on RNS510 was installed only the Europe West map.
Previously to the firmware 5238 josi version, I had a firmware 4120 modified (HDD ratio 60/35/5) from www.rnsfirmware.com and I had some problems during installation (as result, the BAP protocol was unchecked, the RNS skin was changed to Highline from Premium). After installation of 5238 josi firmware the BAP was checked with a VCDS 15.7.
Please advice how to solve this problem with the Sign Assist and Europe East v13 map.
Thank you,
Thank you,
