Hi all.
I find the brakes on the R36 need a couple changes. First of all, the brake pedal sits about 5cm higher than the throttle pedal (I measured it). I find this quite uncomfortable and potentially dangerous because I adjust my seat distance for full control of the throttle, with my heel at the base. Whether I left foot brake or right foot brake, I have to lift either leg to reach the pedal (I'm below average height).
Second annoyance is the extremely touchy pedal. I don't daily drive the R36 so when I do jump in, I cause my occupants to nearly hit the windscreen. The range of motion is too short and too high so I have to baby the pedal.
Both of these issues (for me) make driving it fast somewhat daunting.
I've been looking for solutions. I called Race Brakes in Sydney and he only suggested some low dust Ceramic pads to reduce the pad bite.
Since many VAG parts are cross shared, I was wondering if there was a different brake pedal I could fit that would lower the height.
Another idea I have is to change the push rod to a shorter one. And to possibly reduce the amount of brake boosting.
Please help if you have knowledge or experience, or can point me in the right direction.
