R36 Wagon - Power Tailgate closing issues?
  • #46
    Hello, did you find the solution od you problem? Im having the same issue now
    • #47
      Originally posted by VW_R36suit View Post
      Thanks For that.
      Had a long look throuh the pdf's much appreciated. But I now feel I might need an auto electrician to look into this. Hard on my head that it works to open but not close. And the hard one is the boot light. I closed the tailgate by hand (which I hate to do) and other than the light the car is fully operational. It feels this one is beyond me
      Hello, did you find the solution of this issue? I have the same problem now
      • #48
        Hi, what’s happening with yours? If the tailgate opens ok but won’t shut with the button, check if the rear interior light is on. If it isn’t on it’s probably a faulty tailgate latch. On mine if you play with the latch the interior light will come on and then it’ll close with the button. I have a new latch but I haven’t fitted it yet.
        • #49
          If you need a new latch they are about $140 from VW and $23 on EBAY I needed one for the Polo and got an Ebay one and it works perfectly
          • #50
            No unfortunately I didn't.
            When I use OBD11 I can open and close it without fuss. But still can't find a single fault.
            Had to be placed on hold due to issues that ended in timing chain replacement.
            Anyone find a fix or help?
            M12.5 VW Passat Wagon, 4motion 3.6 DSG 6 speed. A pleasure to drive.
            • #51
              Mine waa replaced under warranty. My issue still continues sadly.
