R36 Wagon - Power Tailgate closing issues?
  • R36 Wagon - Power Tailgate closing issues?
    Hi All,
    I'm a new (to me) owner of a MY10 R36 wagon with power tailgate.
    I've noticed on the odd occasion that when I go to the close the tailgate via the button, that it does not respond in closing.
    The first time it happened (and before I'd read the owners manual comprehensively), I kind of panicked. Thought maybe I would put the key in the ignition again and try to close. Nothing.
    How about starting the engine and trying to close? Nothing.
    As a last resort, I just forced it down manually and could hear the locking mechanism kick in (so no issue there).
    It's happened on a few random occasions since then, and I just close it manually every time it happens.
    I don't have any issues with it opening from the switch in the drivers seat or the key fob, and just wanted to know if there are others out there who have had a similar? Or could advise what I should look for in investigating a fix.
    Thanks in advance,
    Damo.
    2010 .:R36 Wagon - Biscay Blue
    RNS510 | SatNav | DynAudio | MDI | 9W7 Bluetooth | Sunroof | Power Tailgate | Factory Tint
    TBC - Lowline RVC
    Rasie the tail gate all the way to the open position and then hold the button for afew seconds, you will see the indicators flash which indicates it has been 'reset' try this and see how you go matey.
      Thanks for the tip. I'll try it out and report back.
      Cheers,
      Damo
      TBC - Lowline RVC
        So I reset the tailgate and the next attempts to close the tailgate failed. But the next half dozen times closed without issue. I guess I'll keep monitoring it for now.
        Also looking forward to any other peoples advice/experience with this issue.
        Cheers,
        Damo.
        TBC - Lowline RVC
          This has happened to me since my car was about 6 months old. More often that not, the tailgate didn't close...
          So far, 2 x control module replaced and the tailgate switch was replaced as well.
          Last week the car was again in for this issue as I was at the point where the tailgate was never closing. This time they have replaced both motors which power the tailgate. In <6 events since the new motors, so far, so good. I'll leave the jury out though.
          CR Audi RS3
          PW Golf 7 GTI
            Thanks for sharing your experience.
            Cheers,
            Damo.
            TBC - Lowline RVC
              got mine changed under warranty and has been fine since
              2009 Volkswagen R36 Wagon
              1968 Audi F103 75L Coupe
              1966 Volkswagen Beetle Deluxe
                Thanks for the reply. Can I ask what was replaced? i.e. just the tailgate switch? or control modules too?
                Cheers,
                Damo.
                TBC - Lowline RVC
                  they changed the switch
                    Thanks mate.
                    TBC - Lowline RVC
                      Originally posted by damo_t View Post
                      Hi All,
                      Thanks in advance,
                      Damo.
                      Damo
                      I've had exactly the same issue since buying my MY09 R36 wagon last year. I have been trying to find out whether there's anything that seems to make it worse (i.e. rain, heat etc) and so far haven't figured anything out.
                      I will give the reset a go and see if it makes any difference, but like yours, mine seems to work intermittently and when it doesn't I just manually push it down.
                      Any idea what a non-warranty switch replacement might be worth?
                      Wags
                        Originally posted by wags View Post
                        Damo
                        Wags
                        Hi wags,
                        Thanks for sharing your experience. Sounds like we're in the same boat.
                        I've done a quick search on the net regarding replacement, but haven't found anything as yet.
                        Seems to be a lot of parking brake switches though.
                        I'll put a query through VAG, and let you know what they quote.
                        By any chance, does anyone know if it's a possible DIY job for the non-technically minded?
                        Cheers,
                        Damo
                        TBC - Lowline RVC
                          Update. I was able to source a new switch for $44. Funnily enough the tailgate has been working fine ever since. But I may just purchase it as a back up. Seems to be a decent price for OEM.
                          Cheers,
                          Damo
                          TBC - Lowline RVC
                            Great work Damo. Do you have a part number?
                              I'll post it once the part comes in for you. Looking at a couple of weeks, but will definitely update.
                              Cheers,
                              Damo
                              TBC - Lowline RVC
