PASSAT R36
The word about oils first. http://www.vwwatercooled.org.au/f77/...nts-49676.html
Enigine oil: Use the latest (highest) specification oil available. Oil is the cheapest part in your engine (drive train) and will be there for 15,000km or 1 year.
Transmission and gear oils: Unlike engine oils the different brands of transmission fluids shouldn't be mixed and the same apply to gear oils (even if they’re the same grade and specifications). Approved or meet oil specs more about it in HERE
Buying genuine servicing parts from the dealer and keeping the receipts may help should there be some doubts about faults related to maintenance during warranty period. For your and other road users safety, I suggest that you take your car to professional mechanic for your scheduled servicing.
Engine
V6 …………………….................3,597 cc
Compression ratio.:1............12
Bore x Stroke ………………….....89.0 x 96.4 (mm)
Torque …………………………......350 Nm 2400-5300rpm
Power……………………………......220kW (295bhp) @6600rpm
Fuel ............................... 98RON Unleaded
Transmission…………………... 6 speed DSG AWD Haldex coupling
Suspension
Suspension (Front)…………….. MacPherson strut with lower wishbones
Suspension (Rear)………………. 4-link suspension
Wheels and tyres………………235/40/18
Wheel and tyre calculator
Alloy wheels (Omanyt) 18 x 8” with 235/40 R18 tyres
Performance
Top Speed………………………... 250kmh
Acceleration (0-100kmh)….. 5.6s (sedan), 5.8s (wagon)
Fuel consumption L/100km……………….. Highway 8.3 ..... City 14.9 ..... Combined 10.7
Fuel tank capacity…………………70L
Kerb weight………………………... 1,689kg
Min turning radius ………………..5,700mm
Servicing parts
Engine oil ………………………….. 5.5L VW504.00/507.00 supersedes all previous oil specifications (use only VW approved oil)
Oil filter……………………………..
Air filter…………………………….
Pollen filter………………………….
Fuel filter………………………….…
Engine belt………………………….
Coolant ……………………………...8.0L G12+
DSG oil ……………………………....5.2L G 052 182A
Haldex coupling oil……………….0.65L
Bevel gearbox oil …………………
Rear Diff oil ..................... 1.0L G 052 145 S2
Power steering fluid
Brakes
Brake disc front (ATE 24.0125-0158.1)
Diameter: 312mm Vented
Finish: High-carbon Surface coated
Brake disc thickness: 25mm
Minimum thickness: 22mm
Height: 49.9mm
Centering diameter: 65mm
Inner diameter: 146mm
Brake pads front (ATE 13.0460-7184.2)
Brake disc front (ATE 24.0130-0115.1)
Diameter: 345mm Vented
Brake disc thickness: 30mm
Minimum thickness: 27mm
Height: 49.9mm
Inner diameter 140mm
Brake pads front (ATE 13.0460-7200.2)
Brake disc rear (ATE 24.0112-0219.1)
Diameter: 310mm Vented
Brake disc thickness: 22mm
Minimum thickness: 20mm
Height: 48.5 mm
Inner diameter: 169mm
Others can post but
This thread is only for technical information about R36 I will try to keep it as short as possible and please do not make unnecessary posts in this thread. If you post here than post only technical info related to R36 and don’t be disappointed when it gets copied onto the first post and additional post will get deleted in order to keep it short and useful.
Engine
Suspension
Performance
Servicing parts
Brakes
Height: 49.9mm
Height: 49.9mm
Height: 48.5 mm
Others can post but
