So my b7, that I've had for just over a year now and hasn106k on the clock, died a couple of weeks ago. Short drive to the shops, first the epc light and a little bit of surging, then again on the drive home, this time with a CEL and no power.
Scanned it at home, came up with p0087 low fuel pressure (first) followed by p0088 high fuel pressure, reading at 125 bar. Timing angles on both showed zero.
Back and forth with mechanic, and confirmed the high fuel pressure issue was the result of a faulty valve on the hpfp. Replaced hpfp, but it didn't make it 20km before it came up with the p0087 again. Seems to be OK if I keep the revs in 2k to 4k, but I'm not game to drive it on anything but surface streets in the left lane.
Interesting that, when there is a hard ecu fault, the timing is locked to zero. Both are now showing at limit. No symptoms before: no rough starts, no lumpy idle, no whistles.
Mechanic has had the car for a week now and I still am none the wiser as to what it is. He was chasing down a low pressure fuel pump issue, but until I go back on Monday I won't know where he's at.
Checked pcv, all good. Rechecked hpfp, old one same issue and new one no (low or high) fuel pressure errors on a cc v6.
I've got no reason not to trust the mechanic, but I'm not getting answers, and we're both getting frustrated. The car has been undriveable for 5 weeks now, and I'm at the point I'm going to buy a new car and bench the v6 until I can diagnose it.
I like driving it, but I just don't trust it (ps. hopefully the hpfp leading to it running rich was the cause for the high fuel consumption, the last few tanks it got so bad I started driving it like a camry)
Any similar issues? Or thoughts?
Sent from my SM-T835 using Tapatalk
