Water in footwell
  • Water in footwell
    The floor mat and the carpet under the floor mat in the driver's footwell is quite wet and I'm looking for possible causes. The car has no sunroof, the windscreen has never been replaced and does not seem to be leaking, there is no loss of coolant that would suggest a leaking heater core and there is no evidence of water running down the plastic cover over the firewall.
    Has anyone experienced this? Any ideas? Is there drain that is prone to blocking?
    2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
    Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
    Check for leaves and other dirt and debris blocking the drains under your plastic windscreen cowl. If that water cant drain away it could get into the cabin.
      Thanks. I'll check that out. I try pouring water down the drain at the side and if it doesn't flow freely, I'll resort to a hose to blast out any debris (whilst checking for water ingress at the same time!).
        Lucas_R you were absolutely correct. I poured water into the edge of the plenum between the plastic cover and the bonnet hinge. Water ran from a retaining screw in the firewall into the footwell. Problem solved! Thanks.
          Awesome - good to hear the problem is fixed.
            I've got a simialr problem but the passenger footwell. Are you able to take a photo of what I should be looking at (the plenum and the retaining screw)?
              Sorry for the delay. I haven't logged on for a while. Here are photos of the plenum. Retaining screw photo to follow later. The wiring harness passes through a hole towards the outside of the car. Since the harness fills most of the diameter of the hole, it's easily blocked.
Name:	Plenum blockage.jpg
ID:	1860700Click image for larger version
Name:	Plenum blockage 2.jpg
