Radiator Fans change R36
  • Radiator Fans change R36
    Need to replace my radiator fans on my R36 , not sure the best way to remove it, as space looks restricted don't want to remove stuff if not needed for access.
    Any suggestions ?
    If it's anything like what it was on the VW Up! I did a while back; you need to pull the bumper, AC condenser, then pull the whole radiator assembly out to get to the fans.
    I will check the service manual this evening and let you know.
      You are in luck; it's not a bumper-off job
      Remove the airbox intake duct
      Remove the four screws on the fan support tray.
      Unclip the coolant hose from the support.
      Disconnect the power connector
      Remove the fan tray via the bottom (you will need some room to get that out, I hope you have access to a lift)
      Fan screws 10Nm and 5Nm for the tray screws.
        Thanks very much for your swift response , the coolant hose do i need to disconnect the hose from the rad or just where the hose is mounted to?
          No mention of draining to coolant, so it must be just clipped, I will PM you the PDF
            That pdf diagrams make it so easier . thanks for taking your time to upload it
              Also to ask
              what fan is this, the small or the big one?
              006481 - Radiator Fan 2 (V177)
              P1951 - 002 - Movement Restricted / Jammed - Intermittent
              Freeze Frame:
              Fault Status: 00100010
              Fault Priority: 0
              Fault Frequency: 1
              Reset counter: 255
              Mileage: 114004 km
              Time Indication: 0
              Date: 2022.04.24
              Time: 16:54:49
                If you run an output test in VCDS, you should be able to test each fan.
                I would also check to see if the fans spin freely (With the battery disconnected!) the error only shows to be triggered once.
                  Both Fans spin freely by hand, i don't feel any resistance, did output test both spin up at full speed.
                  Think low speed is gone, as i hear fan come on alot at full speed.
