Hi, so always had this problem of fuel level never reading full. Even filled up to the brim but level never went up to full. So I had recently cleaned out the main tank and the pump and thought it might have improved but this didn't work out.
So used the vcds and did an instrument cluster check. The fuel level went up all the way then rested smack in the middle.
Speed needle went to 101 instead of 100 but I had kind of known that any way.
Then I proceeded to max out the adaptation in 30 and changed level from 128 to max of 136, on saving it still only went close to max but not all the way, even when I filled up extra to the brim again. The range increased from 910 to 930 as well, meaning I need to be more wary of when it runs low.
Did a repeat instrument cluster check and it still went to the middle, not more.
No faults or errors seen on scan. So any one got any ideas what could be a solution to this problem, not a big issue just too much free time on my hands.
