My MY13 passat has started to throw a lot of errors. Initially they were intermittent, but now they are present all the time. Since there are multiple unrelated errors I'm suspecting either a wiring or gateway issue?
Any ideas to where to start looking?
Code:
Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
   Part No SW: 06J 906 027 DE    HW: 06J 907 309 B
   Component: MED17.5.2        05 5359
   Revision: PAH04---    Serial number: VWZCZ000000000
   Coding: 0404000C24070160
   Shop #: WSC 40139 959 131616
   VCID: 71C70889681165C758-8025
1 Fault Found:
053271 - Please Check Fault Codes in Control Module for ABS Brakes
               U1017 - 015 -
             Freeze Frame:
                    Fault Status: 01101111
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 207312 km
                    Time Indication: 0
                    Date: 2014.07.04
                    Time: 10:24:01
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 96.0∞C
                    Temperature: 66.0∞C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 11.938 V
Readiness: 1110 0101
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 058 Q    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6563
   Revision: 00043014    Serial number: CU501511237286
   Coding: 0000020
   Shop #: WSC 01049 002 1048576
   VCID: 3FA39EB16EC5C3B79E-806B
1 Fault Found:
006279 - Wheel-Speed Signal from ABS Control Module
               P1887 - 000 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 10
                    Mileage: 207312 km
                    Time Indication: 0
                    Date: 2014.07.04
                    Time: 10:24:10
Address 03: ABS Brakes        Labels: 3AA-614-109.clb
   Part No SW: 3AA 614 109 BK    HW: 3AA 614 109 BK
   Component: J104   C2 450M VD0B 0024
   Revision: --H07---    Serial number: 00000005930578
   Coding: 0001914
   Shop #: WSC 05311 000 00000
   VCID: 77D3369106753BF796-8023
2 Faults Found:
03842 - RPM Sensor Rear Right: Incorrect Signal
            000 - -
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 11
                    Mileage: 207312 km
                    Time Indication: 0
                    Date: 2014.07.04
                    Time: 10:24:20
             Freeze Frame:
                    Speed: 0.0 km/h
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 157
                    Hex Value: 0x0000
01325 - Control Module for Tire Pressure Monitoring (J502)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 11
                    Mileage: 207312 km
                    Time Indication: 0
                    Date: 2014.07.04
                    Time: 10:24:30
             Freeze Frame:
                    Speed: 0.0 km/h
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 191
                    Hex Value: 0x0000
Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
   Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0025
   Revision: --------    Serial number: 56261216601722
   Coding: 349106
   Shop #: WSC 99999 1023 2097151
   ASAM Dataset: EV_EPHVA2C000000000 002008
   ROD: EV_EPHVA2C000000000.rod
   VCID: 44A9915DCF23A06FC3-8011
1 Fault Found:
13637397 - Databus
          U1123 00 [009] - Received Error Message
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 10
                    Reset counter: 11
                    Mileage: 206241 km
                    Date: 2020.01.25
                    Time: 10:37:31
Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         045 0400
   Revision: 00045000    Serial number: VWZCZ000000000
   Shop #: WSC 40139 959 99896
   VCID: 76CD3B95017F42FF8D-8023
   Subsystem 1 - Part No: 3C0 905 861 J
   Component:    ELV          029 0380
   3C0905861J     ELV          029 0380
1 Fault Found:
02829 - Enabling Steering Column Lock from Steering Wheel Electronics
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 35
                    Mileage: 206219 km
                    Time Indication: 0
                    Date: 2014.06.17
                    Time: 09:59:02
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 195    3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 3753F69146F5FBF756-8063
1 Fault Found:
01316 - ABS Control Module
            013 - Check DTC Memory - MIL ON
             Freeze Frame:
                    Fault Status: 11101101
                    Fault Priority: 3
                    Fault Frequency: 9
                    Reset counter: 11
                    Mileage: 207312 km
                    Time Indication: 0
                    Date: 2014.07.04
                    Time: 10:24:20
             Freeze Frame:
                    Voltage: 12.00 V
                        DD
                    Temperature: 57.0∞C
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Speed: 0.0 km/h
                    Count: 0
Address 53: Parking Brake        Labels: 3AA-907-801.clb
   Part No SW: 3AA 907 801 H    HW: 3AA 907 801 H
   Component: J540 EPB4  VW-86594 0010
   Revision:   H19       Serial number: 00000000310424
   Coding: 0022157
   VCID: 364DFB9541FF02FF4D-8063
1 Fault Found:
             Freeze Frame:
                    Fault Status: 01101101
                    Fault Priority: 2
                    Fault Frequency: 59
                    Reset counter: 11
                    Mileage: 206241 km
                    Time Indication: 0
                    Date: 2014.06.17
                    Time: 10:37:32
             Freeze Frame:
                    Voltage: 13.90 V
                    Count: 105
                    Speed: 82.0 km/h
                    Hex Value: 0x1268
                    Hex Value: 0x8004
                    Hex Value: 0x0101
