Hi guys,
I have a 2012 Alltrack 2L TDI with 75k on the clock. A few weeks after getting the radiator leak fixed (new pump & timing belt change) by the dealer, the car is now reporting Throttle Position Sensor Implausible Signal (P0121) MIL.
After doing a bit of research, this could be either a faulty pedal or clogged up Throttle body. As a first port of call i would like to clean the Throttle body but i have a few questions:
1. Is this an easy job? I understand that this needs to be 're calibrated' with VCDS (which I am able to do)
2. Does any one have any advice or Tips? The service manual doesn't really detail much.
3. Does the O Ring need to be replaced?
4. Why does the Ross-Tech website say "TDI's do not have throttle bodies"? [ref1]
Thanks in advance,
Greg
[ref1] Throttle Body Alignment (TBA) - Ross-Tech Wiki
Thanks in advance,
Greg
