About five months ago I had my front rotors machined and I replaced the front pads on my B7 Passat alltrack. Since then the braking performance has declined considerably and its driving me crazy. I replaced the front pads with Bendix euro plus pads thinking they were good, has anyone else been through a similar situation and what are the go to pads these days for a OEM replacement pad that are dustless? as I'm thinking of replacing the pads again.
Poor heavy braking performance after replacing the front pads
Go ate ceramic pads they feel like stock brake good and have stuff all dust plus they last agesOriginally posted by m_azza View PostAbout five months ago I had my front rotors machined and I replaced the front pads on my B7 Passat alltrack. Since then the braking performance has declined considerably and its driving me crazy. I replaced the front pads with Bendix euro plus pads thinking they were good, has anyone else been through a similar situation and what are the go to pads these days for a OEM replacement pad that are dustless? as I'm thinking of replacing the pads again.2017 Golf Alltrack 135tdi All options
Well there's your problem Lady!Originally posted by m_azza View PostI replaced the front pads with Bendix euro plus pads thinking they were good,
It depends on your driving style and what you are trying to achieve.Originally posted by m_azza View PostI've heard good thing about ATE pads I wish I had known earlier, is there any other brands pads worthy of a mention?
The Wagner pads on my Octavia are great but I really doubt you have the same needs as me. Short trips, no noise, less dust, immediate friction from cold.
The Bremtec trade Series pads i fitted to the Accord euro are shockers - avoid at all costs. Wooden pedal. Lack stopping power. Don't come good with heat. Dustycarandimage The place where Off-Topic is On-Topic
Hi
Done ceramic ate pads and rotors. No dirty wheels, breaking capability increased. No noise. Overall,. very happy.
All jobs done by Volkwerke (Doncaster). Will go again there[emoji1]
Sent from my SM-G960F using Tapatalk2014 Passat Wagon, TDI, blue-motion technology, ComfortPower front seats, Adaptive Damping Control, Premium Sound System, Power Tailgate, Sports pack
Thanks for the advise....
Are the standard ATE pads any good? (the non ceramic pads)
and does anyone know of a website that has a ATE part number lookup online for ate pads? as I tried calling ATE and there not able to supply part numbers to the general public.Last edited by m_azza; 28-11-2019, 08:54 AM.
I'm not saying that it couldn't be as simple as incompatible brake lining on your new brake pads and without seeing your car this maybe harder to diagnose, but it can happen when DIY, simply because you don't know how the ABS system works and its complexity.Originally posted by m_azza View PostAbout five months ago I had my front rotors machined and I replaced the front pads on my B7 Passat alltrack. Since then the braking performance has declined considerably and its driving me crazy. I replaced the front pads with Bendix euro plus pads thinking they were good, has anyone else been through a similar situation and what are the go to pads these days for a OEM replacement pad that are dustless? as I'm thinking of replacing the pads again.
The ATE Ceramic or even new genuine pads will not necessarily fix your problem, if the replacement hasn't been done properly. Taking your car to a good workshop or even dealer and explaining what you done will shorten diagnostic time and may be the cheapest option.Last edited by Transporter; 29-11-2019, 06:58 AM.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
I have changed many sets of pads in the past, there is no so called special procedure to replace the front pads on a Passat. The only difference apart from every other pad that I have replaced in the past was the wear sensor plug. Does anyone know of a reseller that supplies ATE pads at a reasonable price? I've spoke with hsy today and they advised they will not sell to the public.
Then all is good when you’ve done it before.Originally posted by m_azza View PostI have changed many sets of pads in the past, there is no so called special procedure to replace the front pads on a Passat. The only difference apart from every other pad that I have replaced in the past was the wear sensor plug. Does anyone know of a reseller that supplies ATE pads at a reasonable price? I've spoke with hsy today and they advised they will not sell to the public.
How were the brakes under heavy breaking before you replaced the pads?
I’m not picking up on you just trying to help you to find out what potentially went wrong?Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
The brakes were working perfectly under heavy braking before hand the only reason why i changed them was because of the pad were worn. If there was something wrong with the braking system I would have thought there would be a light on the dash right?
