Help with Kessy
  • Help with Kessy
    Hi,
    I have purchased used MY11 Pasaat B7 in India.
    Having 2 issues.
    1. Cannot lock and unlock by door handles.
    2. Remote FOB lock and unlock works only when I am very close (literally touching car) to the car.
    I have noticed below errors in Address 46: Central Conv
    Address 46: Central Conv. Labels:. 3C0-959-799-46.clb
    Part No SW: 3AA 959 799 A HW: 3AA 959 799
    Component: 01 KESSY PQ47 083 0337
    Revision: 00083000 Serial number: VWZCZ000000000
    Coding: 00910A0002C60E76300494157E00DF0B00780103243498
    Shop #: WSC 73430 790 00052
    VCID: 4682DBBC31730976F0-8012
    Subsystem 1 - Component: Sounder n.mounted
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE n.mounted
    Subsystem 4 - Component: ViP n.mounted
    5 Faults Found:
    00192 - Rear Left Door Handle Touch Sensor (G417)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 4
    Fault Frequency: 8
    Reset counter: 60
    Mileage: 116805 km
    Time Indication: 0
    Date: 2013.01.13
    Time: 19:12:51
    02863 - Driver's Door Handle Touch Sensor (G415) Incorrectly Installed
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 4
    Fault Frequency: 3
    Reset counter: 60
    Mileage: 116805 km
    Time Indication: 0
    Date: 2013.01.13
    Time: 19:12:51
    02866 - Rear Right Door Handle Touch Sensor Incorrectly Installed
    000 - -
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 3
    Reset counter: 60
    Mileage: 116805 km
    Time Indication: 0
    Date: 2013.01.13
    Time: 19:12:51
    00179 - Access/Start Authorization Antenna; Drivers Side (R134)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 4
    Fault Frequency: 254
    Reset counter: 60
    Mileage: 116805 km
    Time Indication: 0
    Date: 2013.01.13
    Time: 19:24:46
    Need expert advice to fix this.
    Thanks.
    Buy a battery for the remote for starters
      You mean to say battery for car or battery for remote fob?
      I tried changing remote fob battery but it didn't help..
        Get car battery checked and if down change it as well
        Its 8 years old so could be stuffed Take it to a dealer and get faults cleared.
        Passats tend to throw a lot of faults with flat batteries
          Thanks buddy.. I will get battery checked..
          Previous owner has installed normal battery instead of AGM battery, could this be the problem?
            Possibly
              Fixed kessy issue by interchanging front and rear door handle, now left with only 1 fault code.
              1 Faults Found:
              Freeze Frame:
              Fault Priority: 4
              Fault Frequency: 8
              Reset counter: 60
              Mileage: 116805 km
              Time Indication: 0
              Date: 2013.01.13
              Time: 19:12:51
              Tried cleaning contact of door handle but no luck, I think I will have to replace the handle. (Is there any way to check door handle sensor)
              Keyless is working but have few issues.
              1. Car can be locked and unlocked only from driver door handle; that to have to hold the key in hand. (is this default behavior?)
              2. Keyless boot open is not working. (is this default behavior?)
              3. Lock/Unlock from fob button works only when remote is held very close to the car. (Is there any antenna which will increase the distance?)
                1 Faults Found:
                Freeze Frame:
                Fault Priority: 4
                Fault Frequency: 8
                Reset counter: 60
                Mileage: 116805 km
                Time Indication: 0
                Date: 2013.01.13
                Time: 19:12:51
                Fixed Rear left door sensor issue and now able to lock/unlock from all doors.
                Few queries still remain
                1. Have to hold the key in hand to lock/unlock. (is this default behavior?)
                Please help.
                  My remote fob was culprit.. got new one and all issues fixed
                    Good work and thank you for updating the thread.
