Originally posted by Transporter
View Post
Passat TDI running cold any ideas
NEW BEHR ( TH 5 75 ) VAG 2.0 TDI Thermostat Part No 1K0121113A | eBayOriginally posted by drjekl View PostWhats the part number?
Khttps://www.ebay.com.au/itm/NEW-BEHR-TH-5-75-VAG-2-0-TDI-Thermostat-Part-No-1K0121113A/273375441247?hash=item3fa672315f%3Ag%3AhW0AAOSw3HZ bC%7ECj&_sacat=0&_nkw=1K0121113A&_from=R40&rt=nc&_ trksid=m570.l1313&LH_TitleDesc=0
Last question is that I guess i will lose most of the coolant when i open the hose so how much do I need to buy to refill it znd then have to burp it again as well Figured on pouring it in with a small gap in the hose then jamming it together when it hits the bottom.Last edited by Guest001; 29-07-2018, 05:18 PM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
Thanks much appreciatedOriginally posted by Hillbilly View PostNEW BEHR ( TH 5 75 ) VAG 2.0 TDI Thermostat Part No 1K0121113A | eBay
Well mine is $51.99 and comes from a well known seller according to the linked forum Sooner be sure than sorryOriginally posted by drjekl View Post2021 Kamiq LE 110 , Moon White, BV cameras F & B
1 x 1.5L bottle of coolant concentrate should be enough. It make 3L of coolant. Though I’d get 2 bottles to have some spare coolant on hand.Originally posted by Hillbilly View PostNEW BEHR ( TH 5 75 ) VAG 2.0 TDI Thermostat Part No 1K0121113A | eBay
Last question is that I guess i will lose most of the coolant when i open the hose so how much do I need to buy to refill it znd then have to burp it again as well Figured on pouring it in with a small gap in the hose then jamming it together when it hits the bottom.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Yeah, they’re quite reasonably priced these days. Certainly cheaper than the cooling system hoses.
Well Im not happy. Today went for a run up to Montville and back and the B+/**$^$y temp gauge sat on 90 everywhere both up and down the hills. Yet last time I tried as said was all over the place. Cant figure it out but reckon it must have been an airlock thats come right. Have it sitting in the garage with the top off the tank to see what happens as it cools down.
Went and ordered the new part and now seems wont need it so if anyone wants one it will be here in a few weeks LOL2021 Kamiq LE 110 , Moon White, BV cameras F & B
You should be happy, since it was an easy fix.Originally posted by Hillbilly View PostWell Im not happy. Today went for a run up to Montville and back and the B+/**$^$y temp gauge sat on 90 everywhere both up and down the hills. Yet last time I tried as said was all over the place. Cant figure it out but reckon it must have been an airlock thats come right. Have it sitting in the garage with the top off the tank to see what happens as it cools down.
Bleeding the cooling system properly is important, especially in the closed systems.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Well two reasons im not happyOriginally posted by Transporter View PostYou should be happy, since it was an easy fix.
1 Ive wasted $$50 on something I dont need if no 2 was done properly
2 I spent $1500 for the dealer to do it properly.
Hopefully it has cured it2021 Kamiq LE 110 , Moon White, BV cameras F & B
