Hi all,
I have been trying to troubleshoot what could be the cause of the problem.
I have checked the fuses inside the dash and also in the engine bay. The fuses are fine (or so it seems).
I have removed and swapped around the ballasts and tested both on the working (left) side. Both fire up the bulb on the left.
I have checked the wiring loom on the right side and it seems to be fine, as the parking lights come on.
The motor that moves the self adjustment continues to work even when the bulb doesn't turn on.
I think it could be the bulb itself but I'm dreading the removal of the front end to access it.
I did this about a year ago when I replaced both bulbs as they had both stopped working and I needed to fix it before I got a RWC after buying it.
Have you got any ideas?
