Hey There
I bought a gauge and am trying to figure out how to power it.
I am getting a tee to set the sender in with the original pressure switch. I can run the cables into the cabin through the ECU entry.
What should I use for ignition switched power?
The gauge is set up with power, earth and signal and they are all together until they get to the sender end of the run.
I think it makes more sense to pull the power and earth cables through and terminate them under the dash somewhere and just have the one signal cable going to the sender.
Any tips?
Any tips?
