Oh hi,
So. My driver side mirror puddle light died a little while back on my R36, and I only just got around to replacing it with some LED versions instead.
In about 3 minutes I had replaced my passenger side puddle and tested both LEDs to be working. Looked awesome and matched my new parkers. Puddles eBay Link for those interested.
3 minutes later, I had the drivers side puddle installed and.. nothing. I had a bit of a play around to see if anything was out of place or incorrectly inserted, but no dice. All other functions/lights on the same mirror work fine, so I'm not sure if there is a fuse I need to tend to, or if there's something that's a likely culprit.
I did a quick search and everything seems to point to either nothing working at all, or people struggling with a retrofit (neither of I believe apply here).
Thoughts?
Cliffs -
- Drivers side mirror puddle light dead
- Replaced both sides with new super hectic LEDs
- Passenger side works, driver side doesn't
- Both LEDs tested to work using passenger wiring
- Unhappy feeling inside
Thoughts?
Cliffs -
 . Fair point, I didn't even consider checking that part. Hopefully it's some glaringly obvious. The OCD in me can't handle only one light working, haha.
