Hi Guys,
Have been reading up on changing the oil and filter myself on the DSG (08 R36). There are many variations on the amount of fluid to put back in unless you are following the temperature monitor then drain to the top of the level tube method.
Why would one not weigh rather than measure the volume of the oil removed to get an accurate amount to reinstate? If the temperature varies the volume so much surely weight would be a much better measure?
I was thinking of zeroing with my drain pan on the scales, draining and then weighing to see how much. That way it should not matter what the temp is?
Am I missing something? (I do that a lot)
Cheers,
Nigel
Cheers,
Nigel
