Hey all,
So tonight I replaced my parkers with LED, and in doing so noticed two issues. One is relatively easy in that the factory bixenon HID globes are not as white as the LED parkers, a quick Google tells me they are probably 4300K, in which case I'd probably be looking at 5000K or 6000K replacements. Has anyone done this/can confirm what worked best for them?
The harder issue is that the projector lens itself seems to be foggy or discoloured. Enough to not only bother me but also probably to mess with the output as well. Is there a known fix for this? I assume replacing the lens is out of the question. Picture below showing the bad lens and the mismatched colours, although it's a lot closer in real life than the picture makes out, certainly 50x better than the rubbish incandescent parkers.
