Hi All,
I had a chance to have a look at the standard amplifier in my MY10 R36 Wagon and took some photos.
Unfortunately, the Dynaudio Retrofit (Plug and Play, done by member nermal on 2008 R36) wont work me. Another member
Timlin had trouble to plug in his Dynaudio Amp as the plugs are different on his (2009?) R36.
So it looks like VW changed amp wiring design between model years. Maybe VW did not want people retrofit the optional Dynaudio. The change probably happened when VW updated the cluster. This may also explain why he Dynaudio Retrofit Kit comes the wiring looms(due to the plug change).
For 2008 R36 owers, they are lucky as Dynaudio is plug and play.
For 2009 and 2010 R36 owners, Dynaudio Retrofit isn't an easy job at all. Dynaudio Retrofit wont be on my mod list anymore. I will be just getting used to the standard system.
Here are the photos I took, note that the amp is square shape which is different to Dynaudio amp.
Part Number 5K0 035 456
