R36 Wagon RVC Install Questions
  • R36 Wagon RVC Install Questions
    Hi everyone,
    Well today I received my RVC so I have a couple of questions before I attempt to install. Does anyone have any idea which side of the car to pull all the wires down? Without seeing my car, are the door sill/scuff plates hard to get off or are they simply screwed down? I am currently trying to find a how to video so I will keep looking but if any knowledgeable person knows of one, or has done it themselves, some advice would be appreciated greatly. Sorry if this has been asked before too. Thanks a lot.
    2013 Touareg V8TDi - Black, LED Interior Mods, LED Projector "VW" Door Courtesy Lights, 20" VW Mountain Rims with A/T Tyres, Pioneer SX Roof Platform with some 4x4 accessories and a whole lotta torque
    Hi mate, it will be similar to GTI installation. I read somewhere about the GTI install, they run the cable through passenger side. Worth to check my-gti.com.
    for the sills and scuff panels, they are clipped on so just pull up.
    Just wondering if it is possible that just tuck the cable under the sills/panels, i am really reluctant to unclip panel as most of the time something will be broken and scratched. I love to have the RVC but pulling thing apart hesitated me now...
    2018 BMW 125i M Sport |AlpineWhite|719M JetBlack|BlackLeather |ComfortPackage|Sunroof|WirelessCharging
    2010 MY10 R36 Wagon | Biscay Blue | Power Tailgate | RNS510 | MDI | RVC | 51,000 km |Garage Open Button | Dead Pedal Mod | OE Fit DRL | VCDS | Sprint Booster | H&R Rear Sway Bar | Alcantara Steering Wheel | Dual Reverse Light | 19" Bentley Wheels (BBS Forged Split) | Michelin PS 4S
    2005 MY05 AH Astra HatchBlack | Facelifted SRi Looking | OpeliZed | Whiteline RSB | Eibach ProKit
      Yes installation would be similar to GTI. The cable will be too thick to tuck under the sill. I tried to tuck a basic two wire loom under the sill for rear footwell however gave up and just pulled it up. Those clips will go back in easily however make sure that you have it all lined up before bashing it together.
      you will also need to be very careful when pulling the rgb cable through the channel to rear hatch.
      ps. if anyone wants a cheap rvc highline kit for wagon with all the cables, controllers etc then pm me. open to offers.
        Cheers guys. Appreciate it. Im gonna try and have a crack on the weekend to at least try and install part of it. Gotta then try and get it coded in.
          Are you installing a highline camera with control module? coding is more difficult with highline.
            Nah mate, as far as i know it's just a lowline. I dont really need to spend big biccies on it. Just gotta have something rather than nothing
              Well, ive been beaten. It has got me stuffed how to pull the signal wire through the rubber boot around the wires near the hinges. I managed to get the red power wire through, somehow. I think that i can get an earth for the brown wire on the hatch itself, and the blue wire which i think is the positive for the camera can go to the positive of the reverse light although i was told to just splice it into the red wire! But the signal/picture wire has me beat because it has a reasonable size plug on the end near the hatch. I wonder if a vw dealer knows how to install them because there is no physical way of getting through that boot. I cant get the bloody thing out. Why do they have to make it so hard to do? It really has me angry because i hate getting beaten by something like this! Aargghhh!
                I know which wire you are talking about, it does go through but it's a real biartch. I tied a string to the plug, threaded the string through the rubber boot and pulled with one hand whilst squeezing the rubber (making room) with the other. It does goes through in the end mate!!!
                Sent from my Nexus 7 using Tapatalk
                2012 CS K04 GTI | GIAC | APR RSC 3" TBE | VWR Intake | KW V1 | OEM R Bi-xenons | OEM R Tails | Unibrace UB | S3 Intercooler | podi boost gauge | OSIR body kit | BBS CH
                  I dont see how mate. There is no room on the plastic part facing the interior. It is a silly idea. I cant believe it. I dont see how a VW dealer will do it either! If there was some way to pull the rubber away from the body then it might be possible but i cant pull it out
                    I have no idea if this is even relevant, but an electrician trick is to use a rod (ie. fiberglass fishing pole), push that through the tight spot, tightly tape the cable/plug/whatever onto it and pull it back through.
                    Not sure what you're trying to thread through where, but I hope this info is useful somehow..
                    2018 Arteon R-Line - Black, Sunroof, Dynaudio, 20" Wheels, RacingLine: Stage 2 ECU+DSG|380mm BBK|Intercooler+Hoses|Oil Cooler|R600 Intake|Adjustable Front Droplinks|Dogbone Insert|Subframe Brace+Alignment Kit|Propshaft Alignment Kit, Milltek: Zirotec Downpipe, Harding: Front+Rear Sway Bars|Rear Droplinks, Other: OSRAM Dynamic Indicators, EvcX Throttle Controller, 034 (RED) Coil Packs, Various Carbon Bits
                      Thanks mate but the issue is that the rubber is sort of right angles but the physical hole is not big enough. Gonna have to do some phoning around i think
                        worth a read here?
                        OEM backup camera installation for mk5-mk6 VW Golf hatch badge | VW TDI forum, Audi, Porsche, and Chevy Cruze diesel forum
                        Run the coax and the red/white cable through the rubber pipe connecting the rear lid with the body work. It will just about fit, compress the rubber tube length to make it easier. The supplied red/white cable is not long enough to reach the rear boot lid and has to be joined after it exits the rubber tube, the join can be hidden behind the plastic trim that runs up the side of the window.
                          Oh now I know what you are referring to. To get it past the hole you have to take off the plastic bit & reassemble once it threaded through the rubber bit. The plastic bit is easy, just unclip & it falls away, thread the wire through & your done.
                            Thanks mate. Thats the little sucker that i cant separate from the body to even have the chance. If here are some clips on the inside, it is near impossible to get fingers in there so that is where i am at
                              Check out the link that R36 Passat posted. There is a pic of how it looks when apart. "To get the coax cable through the trim and rubber pipe it’s necessary to remove the outer blue housing. The purple clip just pops off and the blue housing is held on by a clip. The coax connector only fits the housing one way round." I remember it's not that difficult...
