so you think the silver is not a bad buy as well. do you think it comes down to flicking a coin?
Need your opinion please
I just read description about the car...but still, you have to be cerefull and check all option for yourself...even if do not have xenon light still good choice ...but you have to check all options...
Sent from my GT-I9305 using Tapatalk2014 Passat Wagon, TDI, blue-motion technology, ComfortPower front seats, Adaptive Damping Control, Premium Sound System, Power Tailgate, Sports pack
First car do not have xenon light...i just resd dscription...
I do not beleive second car has too...maybe just dealer mistake...
Check factory fitted features....that can not be true...
Let me know what you decided. Good luck
just note
enon light with proper auto levelling installation cost around 3.000 au$...i do not have and after while i decide that not wort to go...only update i done was rns510 e series and premium bluetooth (with voice control) installation. Everything done by vw and i am very happy
A couple of items:Originally posted by revhead1016 View PostAnd I also saw this one. Comparing the two. Which one is better buy?
- The first car appears to be fitted with an aftermarket head unit (and probably an aftermarket RVC as well).
- The second car has the older RNS500 satnav unit, which is not MP3 compatible (according to the MY08 spec sheet that I have) - the 'standard' 6-stack head unit is MP3 compatible.
- The second has twice the mileage of the first, but seems to be more optioned up - satnav, electric heated memory seats, sunroof, bluetooth...
Neither of the two cars you listed have the factory bi-xenon headlights.Originally posted by revhead1016 View Posthow the hell did you know that this car has Xenon light. also are you saying the one in Sydney doesn't have that light.
You have to look carefully, but there is a difference. The non-bixenon cars have a separate high beam reflector, while the bi-xenon cars just have the park light in that position. If you look between the projector lens and the park light section on the Passats fitted with bi-xenon headlights, you'll see the angled reflector for the static cornering lights.
The rest of the car: 2008 Volkswagen Passat Type 3C R36 MY08 Direct-Shift Gearbox 4-MotionLast edited by kleung; 03-01-2014, 02:38 AM.
Here is what the codes in the handbook with the original car decode to. NO XENONS MENTIONED, NO SATNAV EITHER.
Satnav code is 8AY Mine has Xenons but they are not mentioned in option codes but may be in the car codes which are MSU LA8X NV
They came as part of the driving package
Found my Passat codes and Gas discharge headlights are PR number 8IM family is HSW
X8C = National sales program Australia
B0R = Component parts set, complying with vehicle type for Australia, various parts
CA5 = Alloy wheels 7.5J x 17
G1A = 6-speed automatic transmission
HK0 = Tires 235/45 R17 97W x1
J0L = Battery 340 A (70 Ah)
D3X = 4-cyl. turbo diesel eng.2.0 L/103 kW 16VTDI with pump-jet injection system base engine: T9G/TB3/TM0/TP0/TC3/TD3/TQ0
V0A = Tires w/o specification of tire brand
1AT = Electronic stabilization program (ESP)
1G3 = Alloy spare wheel with original equipment tires
2ZB = Leather multi-function steering wheel
5RV = Right exterior mirror: aspherical
5SJ = Left exterior mirror: convex
TB3 = 4-cylinder diesel engine 2.0 L unit 03G.B
3S0 = Without roof rails/roof load rack
8T2 = Cruise control system (CCS) electronic
0G2 = Selector lever
8YM = Radio with CD player (high-end)
8GU = Alternator 140 A
1LH = Disc brakes, front
L30 = Suspension range 30 installation control only, no requirement forecast
0YD = Weight range 4 installation control only, no requirement forecast
G07 = Front shock absorption
0GG = Emission standard EU4Last edited by Guest001; 03-01-2014, 11:04 PM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
