R36 front Brake Pads (EBC)
  • R36 front Brake Pads (EBC)
    After only 4 months of having the EBC red pads (with EBC slotted & dimpled rotors) on my car they have warped the rotors
    Every time I brake the whole car shatters.
    Will need to replace the front brake pads
    Any recommendations???
    Dust wise and performance wise they were great.
    Have been recomended RDA Extreme pads
    The pads are for everyday use.
    OMG i was just about to order a set of EBC Slotted rotors and EBC red pads from the UK. I am really glad you posted this.
    Back to the drawing board then for some rotors
    I have read that hawk make some really good pads too?
    R36
      I think the rotors are good its just the pads that caused the issue.
      Im keeping the rotors machine them and put on new pads.
        Did you find with that combo your stopping power was any better? I guess its hard to tell if your just driving on the street and not on a track.
        I need new brakes all around and im unsure if i should just get some ebc green stuff and cheaper slotted rotors or go with something better.
        R36
          If you need new pads - get Remsa's from GSL Rallysport (sponsor on here). They are fantastic pads. Low dust, low rotor wear and noiseless like the OEM pads. I've been running them for 2.5yrs now and not a single drama.
          GSL will be able to sort you out with new rotors too (if you need them). Just have your car's VIN number handy to quote them, as they need this to verify the right part number for your car.
          Originally posted by gslrallysport
          WHY REMSA?!
          Remsa pads are the pinnacle of European quality. Remsa are rated to 650 degrees (versus 550 for something like QFM HPX or Bendix Ultimate), whilst still delivering VERY low rotor wear and noise! Remsa come with noise reducing features such as a relief grooves and shamfers in the pad material, as well as a soft backing shim as standard. Remsa also come standard with the electronic wear sensors where required!
          We've been supplying Remsa to high performance street road cars like Porsche and Ferrari for many years with pricing starting from as little as $79 per set!
          Introduction
          Remsa was established in 1970, with its 39 years of extensive manufacturing knowledge and experience in producing automotive brake parts, it is now a leading company and placing a significant position in the world’s automotive brake parts industry. All Remsa Brake Pads are produced in factories across Europe. It has established ten production and logistic plants across Europe and America supplying customers with exceptional quality products and services..
          Remsa’s brake pads have undertaken a comprehensive Road and full scale dynamometer test. AK- Master Test evaluates that the quality of Remsa brake pads are in best performance and going beyond the O.E results of some of the most popular and extended European Vehicle.
          Remsa manufactures over 100 million pieces of brake pads annually in order to meet world demand and supply its customers a most complete product range. The range cover up to 99.4% of European, American, Japanese, Korean and Australian applications with more than 2000 references. Accessories that are fully in line with OES specifications are also included in most Remsa Brake pads. All Remsa pads are produced to OE specifications. Most aftermarket supplier in Europe evaluate ECE90 specifications as excellence. However, Remsa only set this as their minimum standard.
          ADT (Alpine Decent Test)
          All Remsa Brake Pads are tested by Remsa technical driver in Austrian mountain called Grossglockner with a 12% average slope and 18% at the maximum fall to ensure that all the brake pads functions even under this extreme condition.
          HPT (High Pressure Treatment)
          This is an unique manufacturing process of Remsa. 90% of brake pads reduce their functionarity at high temperature. However, all Remsa brake pads are treated at 650 degree high temperature and applying 10,000N press force per brake pad thus ensuring that the complete surface of the pad is evenly cured and keeps the reliability even at high temperature.
          Environmental Friendly
          Remsa Brake Pads are unique from an environment standpoint, they are all free of heavy metals such as, among others, lead, copper and asbestos. it is well known that these metals have devastating effects not only on the environment but also on the health of human beings, especially the drivers!!!
          All Remsa Brake pads undergo a strict set of test procedures to ensure complete safety of all pads, including:
          * Krauss Test
          * Compressibility Test
          * Heat transfer Test
          * Shear Strength Test
          * Dynanometer Test
          * Alpine Test
          * Hill hold Test
          For more information or to purchase any set of Remsa brake pads, contact GSL RallySport:
          GSL RallySport
          Ph: 1300 884 836 (within Australia)
          Ph: +617 3188 7534 (International)
          Email: sales@gslrallysport.com
          Web: GSL RallySport... The Motor Sport Revolution!
          Address: Unit 5 / 14 Buttonwood Place, Willawong QLD 4110
          [/center]
            The performance is good.
            The issue is if you have R36 they dont produce the green brakes only red and yellow (race)
              ok i have just been through an annoying experience with an attempt at brake upgrade. car is an R36 sedan.
              after researching on the net, i decided to go for DBA slotted rotors and QFM HPX pads. i was after performance with no dust
              this setup worked well but the pads sqeualed like hell. i'm talking every time i braked. horrible.
              swapped them for a set or remsas. the pads are very good but the dust is probably WORSE than standard.
              am very happy with the combo but need weekly cleaning of my wheels. the rotors are top notch and highly recommended.
              if i were to do this again i would upgrade the rotors and use standard pads.
              big big big thumbs up for GSL rallysport. while they do take time to reply to emails, they are genuinely a top company with customer service something which lacks in the car industry.
                Since this thread I think i will stay away from EBC rotors/pads and go with GSL with some DBA 4000 T3/T2 rotors and import some Hawk performance pads since they rate so well with the GTI/R32 community. Please someone tell me that setup is ok, otherwise ill just go non slotted rotors which is boring!
                R36
                  Rotors being machined and pads replaced with RDA extreme brake pads next week.
                  See how we go with this.
                  Hopefully saves my rotors and not a lot of brake dust gets produced. Will advise of outcome
                  Might have a set of reds up for anyone interested
