Okay after weeks of messing around i managed to get to this stage after posting this
1998 V6 auto passat- Bought the car off someone who said it hadn't been running for 1-2 years.
It takes about 10 or more seconds of cranking before it will fire. It then idles fine.
If you try and rev it, it goes to stall, if you quickly pump the throttle the revs slowly increase and i can get them upto about 3000rpm
If you put your foot to the floor it goes to stall.
I can hear the fuel pump running (Slightly grizzly in my oppion)
I have replaced the fuel filter
I have changed the spark plugs, from Bosch +4 to the NGK ones
I have cleaned the throttle body, and done and adapted the throttle with my Ross tech cable
No fault codes in the engine ecu
I have put a jerry can of BP 98 in it with 3 bottles of penrite injector cleaner, which is currently sitting outside idling...
When i was changing out the spark plugs, one of the spark plugs leads had a little cut on the bit that goes into the spark plug hole, with a little bit a what looks like white arking, so ill get new ones of those...
