V6 passat lane assist
  • #16
    camera is there, BTW like the desert Beige interior would have prefered it to black as it does not show sand as badly. HOpe fully should be fixed come thursday. BTW does the passat have the static cornering lights enabled? just wandering as I can only seem to get one set of fog lights to work with the switch.
    2013 V6 Passat Candy white, sports pack, towbar, Drivers visability and assist.
    • #17
      Yes it does they only work at low speed however At under 15kph I think.
      They come on when you turn the steering only
      It does explain about them and most other things in the Manual
      • #18
        Problem fixed by my local VAG, apparently did not have the correct region coding, an issue which appears with the towbar installation. Now the static cornering lights and lane assist are both working.
        CHeers
        • #19
          sweet, i was right with the towbar then.
