Got sick of looking at the standard yellow corning lights so have just replaced with Phillips Crystal Vision. Colour now matches the Xenons. Has anyone replaced the parkers and puddle lights, if so what have you used and is it a simple swap? With the puddle lights , does the plastic just clip off or does the mirror need to be dismantled?
---------- Post added at 06:25 PM ---------- Previous post was at 12:07 AM ----------
For those that are interested to remove the parkers simply pull on the flat plastic tab. This can be located by following the two wires that seem to disappear in the headlight behind the cover. Haven't figured out the puddle lights yet, hopefully the lens just pops out with a screw driver. Will give it a go tonight.
