Hi everyone,
After some guidance on this please. Have had my New (demo) Passat sedan for 2 weeks now. Has just clocked 5000km's.
At times, when touching the brake pedal, there is a slight resistance at the very first movement of the pedal, then it moves through its pedal range normally. Having driven many late model VW's, this is not normal. THey normally travel very smoothly. And also, it is bloody annoying as each time you press the brake pedal, it feels like there is something, ever so slightly, holding the pedal at the top of its range then it releases and works fine. I have pumped the pedal through its full range of operation a few times and this makes it happy for a few minutes then it starts this rubbish again.
It does not do it everytime, but most times if there is sufficent time (a few minutes) between brake pedal presses.
Could it be something as simple as adjusting the range of the push rod into the booster?
I have to drive from Tamworth to Sydney on Wednesday and return Friday, so I am hoping it is a simple and quick fix because the wait time on VW service here can be a week or 2.
Shane
Shane
