Every thing was going/running well on the Little Beastie till yesterday when a metal on metal grinding noise started coming from the LHR wheel!!!!!!!!!!!!. The handbrake works fine so it must be the drums. Getting Michael at CVWC at Tuggers to check it out next Thursday.
Arrrrrghhhhh
Jack it up at the rear and spin the wheel independantly. I recon it's gonna be handbreak too.Originally posted by WhubbsieThere is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
I think so too. I was playing around with pulling the handbrake on and off at low speeds and the grinding noise ceased when I pulled it up when it was under load. I am not confident enough to fiddle with removing the drum housing so I will leave it with Michael at CVWC to check it out. Thanks for your input gents.Old Skool Passat Power Rules!!!
1974 Passat LS with a SEAT 1.8, 32/36 Weber, full performance exhaust and a K&N filter. 80kw at the wheels??
The new SEAT 1.8 is magic. Had a few teething problems, needing to replace old and perished bits and pieces that we did not change when we put the engine in.
I also Put in bosch 4 pin spark plugs and a decent set of leads, which has made a huge difference. Cant wait for Carbie and Exhaust.
