Seems this is going to be the first problem with the car. Anyone else had a problem with over active climatronic? I have to set mine at 26degrees or else I've got icicles hanging off the visors. It sort of works in that on a cold morning when set at 26 it will run the heater, but as soon as the sun starts hitting the dash and the interior temp goes up just a few degrees, on goes the air con. On a hot day the fan runs at 4 with seemingly little let up on the compressor - and the air coming out is freezing. In fact, the air coming out the vents must be around 1 degree it's that cold. Problem is even on a hot day with the temp set on 26, I still have to keep turning the air con on and off.
Does anyone know if they are calibrated and if you can alter the parameters- or just a fixed sensor?
