Originally posted by dopey
View Post
The 1156 in super white about half way down the page. But you could go for any style as long as it's a 1156 base (not sure the spider lights would fit though).
I added a couple of their sealed resistors ( LED Flashers Blinkers Resistors Load Equalizers for Turn Signal Replacement Bulbs Rapid Flashing Fix ) and no bulb out errors. It's an easy quick job, just screwed them to the horn brackets.
If you want to know how to remove the DRL/fog light panel from the car to replace the bulbs, forget the instructions in the handbook! Let me know and I'll do a write up as it's a PITA if you don't know how to do it the right way - and you'll probably end up snapping a couple of lugs when refitting it
It's definitely worth doing IMO, it looks heaps better, and much brighter - or at least much more obvious than the standard dull yellow bulbs.
