Joining the queue of Passat owners with injector problems (TDI wagon carked it)
This is a sticky topic.
  • Hi all,
    Just been reading this thread after experiencing the same as everyone else. My VW is a 2006 TDI Passat (83,000kms and owned it since new) and after re-fuelling I could not start the car the next day. RACV came out - same story, could not start, and car was towed to Volkspower in Melbourne where it is currently being diagnosed. Looks like wiring loom and injectors might need replacing. Could be due to dodgy fuel??
    I might contact my VW dealership on Monday to see if I have any recourse. Would really like to know if replacement injectors, if required, have been redesigned to prevent this from happening in the future.
    Also experienced a problem with the electronic handbrake last week -could not release it, and button was flashing. Was told by VW that I would need it towed to workshop, but eventually brake released and I was able to drive the car without further incident until 3 days later when the above happened. Am told the two events are unrelated.
    • Hi guys,
      my 06 passat tdi 103kw with all the same problem... engine was off in the middle of busy traffic so danger(4injectors replaced), DSG replaced. second handbrake replaced and now i can hear winding noise like tyred so loud in low km and whistle from my a/c...
      otherwise perfect car for family...
      Lucky I extended the warranty to 6 years.. thinking of selling it after out of warranty...
      • I have a 07 TDI Passat, same problem with the hand brake switch, stranded me in a car park for nearly 3 hours, and was towed to Solitaires here in Adelaide to be fixed. Common problem in Passat, VW’s have changed the position of the switch in later CC and B7 models, hope they work better. May need a program upgrade as well, not sure for what years that applies to. Injectors are working fine, need to find some wood to knock on, normally they go on the 125 kw motor, not the 103 one. If you have always have had the car service by VW’s, see if they are willing to come to the party, to have to pay for them yourself will be expense.
        Need to find better quality wood, injectors packed it in, refer to the diesel section for the full story.
        Last edited by transporterq; 22-11-2011, 09:23 PM. Reason: Injectors finally gave up, 20 KM's out of Geelong.
        • Originally posted by Ticker911 View Post
          Has anybody else had ongoing problems after the install of the new injectors. My injectors, wiring loom, computer was replaced and i have had nothing but problems since, Looks like they are going to change the gearbox mechatronic unit out and i have just got home now after sitting in a car park for half an hour trying to get the handbrake off what next is the question thank good that it is still in warranty Just can you get an extended extended warranty????
          All common faults with the B6 Ticker911, there is a log page in the "Diesel" section to log the injector issue.
          WestOiler125
          MY13 Passat Alltrack
          125kW 2.0L TDi DSG
          • Hello,
            I have a similar problem with my 2007 2.0L TDI BMR.
            Went to my local service guy who whacked on the VAG-Com and come up with this:
            '01137 Exhaust Pressure Sensor 1 (G450) Implausible signal P0471 Short With Power Intermittent.'
            He said that a previous car had come in with that exact same fault and ended up dying two weeks later.
            My fuel went from avg. 5.3L/100km up to 6L/100km, it also sounded like a truck, lost power and gears kept down changing.
            I have just contacted my local VW dealership and asked if this is under the recall campaign, was told yes, so am booking it in this Thursday.
            So I don't know what is happening in Australia, but it seems like it could be covered in New Zealand.
            Electronic Brake switch:
            Have also had problems with this, has been replaced.
            It is an extremely easy fix......do it yourself
            * The side cover at the the edge of the dashboard comes off with a gently pull with a flat baled screw driver.
            * Put your fingers up in behind the switch and push it out
            * Pull the contacts off and replace the switch
            * Push the switch back in.
            I buy my parts from USA.
            For you guy's this is a no brainer, with the good exchange rates.
            I use this site, have even shipped boot liners and and nets down here with no problems and its a hell of a lot cheaper than buying here.
            http://www.vwdiscountparts.com
            Under: Brakes,Parking brake, Switch passat, park hold
            Anyway I hope it all goes well this Thursday when I drop it off............
            Will let you all know what happens.
            • I own a Volkswagen Passat 2.0L TDI 103kW DSG Wagon. Driving on cruise control, engine suddenly failed. Car is 6 months out of standard 3 year warranty, done 83,000 kms. Had it towed to VW Gold Coast where it is regularly serviced (tried a mobile mechanic first but he failed to diagnose the problem). I was just informed by service manager that the diesel injectors have failed but luckily this part is COVERED UNDER 7 YEAR VW WARRANTY (saving me many thousands of $$$).
              Everyone who has this problem, irrespective whether or not they are getting their car serviced by VW dealers should get their injectors replaced FREE OF CHARGE on failure, if the car is less than 7 years old.
              Also can anyone tell me what is involved in getting an extended warranty from VW? Can I still get it ? What is the cost?
              Cheers.
              • I too are now thinking of the extended warranty, what is involved and what is covered. Is it a VW backed warranty or some third party insurance broker?
                • Well,
                  Finally got the car in for it's service yesterday. Collected it this morning. They told me that the fault was the DPF (diesel particulate filter sensor)
                  But they did replace the injectors under the replacement campaign after explaining that "there was no problem with them, but we thought we better just update them for better ones"
                  Yeah right.........
                  Anyway it's done.
                  But this has left me with a very bitter taste... will never buy a VW/Audi/Skoda ever again. And are now looking for a new car.
                  • Recently purchased the 2007 My08 Passat Wagon TDI, worried after reading this thread, 60k almost done. Rang up Volkswagon Australia and the dealerships as well, but no one stated anything about the Injector service recall/warranty. They said nothing is associated with your VIN. Currently car has no issues but would like to know how to get it done before something like this happens on the road or worse highway with a baby in the car!!!!
                    Also if I were to get an extended warranty, would it be covered at that dealership only or any dealership/ Independent would cover it?
                    • Originally posted by sn809 View Post
                      Yes it will, it is a VW certified extended warranty and the car is covered everywhere, with the usual caveat that regular servicing needs to be carried out. Worth ringing all your local dealers, as I saved $1K for 3 yrs by doing this. Not cheap, but way cheaper than a new DSG!
                      WestOiler125
                      125kW 2.0L TDi DSG
                      • Appreciate the reply. Have contacted a few, getting a warranty by Allianz is that the one you are talking about??
                        2 Years 50,000 kms $1990
                        3 Years up to 75,000 kms $2390
                        Is that a good deal??
                        • Last February I paid $2189 for the "VW" 3 year or 60K extended warranty which is underwritten by Allianz. At the time Alianz was a little more expensive compare to other 3rd party warranties but it appears on paper more comprehensive and better limits on specific items like tow costs etc.
                          Just check the fine print for things like limits on components - no point if there is a 2K limit on a transmission for example.
                          MY12 Volvo V60 T5 Tekink in Ice White
                          MY08 125Kw TDI DSG Wagon in Mocca (02/08 - 03/12)
                          • Originally posted by avantgarde View Post
                            .... I was just informed by service manager that the diesel injectors have failed but luckily this part is COVERED UNDER 7 YEAR VW WARRANTY (saving me many thousands of $$$).
                            Everyone who has this problem, irrespective whether or not they are getting their car serviced by VW dealers should get their injectors replaced FREE OF CHARGE on failure, if the car is less than 7 years old.....
                            Thought I had dodged a bullet until mine just died. Started normally and idling for 15 seconds while I put away the sun shade. Minor engine shudder and stopped and would not start again. Felt just like it had run out of fuel (it hadn't). Towed to local dealer after work friday and they looked at it Tuesday PM.
                            Service manager rang to advise they would be replacing all 4 injectors plus harness (needed no prompting from me at all). He also advised that VWA warranted these parts for 7 years rather than std 3 year warranty. Only cost to me will be my choice of $25 to cover air freight of parts ex Sydney as warranty only covers road freight. Not material in this case but I also have the extended warranty.
                            MY2008 purchased new in May 2008 and now with 50000Km
                            Only 4 days after a 7400 odyssey down and then up the east coast without missing a beat so very glad I was only 2Km from dealer. Cost me $144 to join RACQ which covered the tow and was cheaper than the $175 call out for non members!!!!
                            Granite Passat sedan TDI (125kw), DSG, beige leather
                            Candy White Polo 6R, 66TDI, DSG, no options
                            • Could this issue affect the new b7 125tdi passats??
                              • PD only not the latest common rail, although their injectors are failing, but far less often, as they are now external of the oil. As of 23-11-2011 there is a TPI out to all dealers about certain Siemens injectors, see the thread in the diesel section, I have a set of the supposed "bad" injectors....you can check your car on Erwin for 5 euro.
