how to open door manually
  • #46
    Originally posted by Maverick View Post
    Why post without reading the thread
    LOL
    MY12 Volvo V60 T5 Tekink in Ice White
    MY08 125Kw TDI DSG Wagon in Mocca (02/08 - 03/12)
    • #47
      battery is in the boot not under the bonnet
      • #48
        Ummm not in all Passats. Only in the V6s I think. It's under the bonnet in the 4s.
        • #49
          Not in the Diesel models...Not that it matters
          • #50
            I've just ordered a slice!
            • #51
              yep, the cable under the car to the starter motor is the go, this is what the RACQ did to my car when the battery died after I hadn't driven it for a couple of months.
              Gone...........R36 Icelandic Gray Wagon
              Specialising in off-topic discussion
              • #52
                I Guess the OP has given up or solved their problem by putting a brick thru a window...
                • #53
                  Just for a laugh, I tried the "pop the cover off the door handle" entry method and it does work but the locks are definitely electric so a disconnected battery will be a show stopper!
                  I did note that if you unlock the doors this way the red LED on the door continues to flash so I assume the immobiliser is still active.
                  • #54
                    The immobiliser is deactivated by inserting the keyfob (or on other models inserting the key into the ignition) and as the car starts a transponder is powered up in the key that authenticates and a new code is written. If this process fails the car will stop a few seconds later and display a warning.
                    website: www.my-gti.com
                    • #55
                      So did the OP ever et this problem sorted??
