Originally posted by Rocket36
View Post
how to open door manually
Yeah, that's what I tried (the [ img] and [ / img] without the spaces) and all it put in the post was the link.. I took the link from the address bar in Explorer. Will keep looking in Photobucket..MY08 Passat 2.0 TDI Wagon
Trialling golf ball aerodynamics theory - random pattern, administered about 1550 on Christmas Day, 2011.
The link on it's own is: http://i624.photobucket.com/albums/t...g/DSC00268.jpgOriginally posted by passatpout View PostYeah, that's what I tried (the [ img] and [ / img] without the spaces) and all it put in the post was the link.. I took the link from the address bar in Explorer. Will keep looking in Photobucket..
With the code: [ img ]http://i624.photobucket.com/albums/tt321/alpout/Passat%20Manual%20Unlocking/DSC00268.jpg[ /img ]
With the code but without the spaces:
Trust me - it works... It works for any image link on the internet!
Nope, I left my battery connected.Originally posted by origin View PostHi Rocket36 / passatpout,
Thank you for your help and image..
I did that but no luck.
Did you unplug your car battery before you tried that?
origin
Might be time to call VW about it... it should still have roadside assistance available..MY08 Passat 2.0 TDI Wagon
Ah-hah.. thanks Rocket, all done now, I think I can work it out from here..Originally posted by Rocket36 View PostThe link on it's own is: http://i624.photobucket.com/albums/t...g/DSC00268.jpg
Trust me - it works... It works for any image link on the internet!MY08 Passat 2.0 TDI Wagon
Same for MY09...Originally posted by bennobee View PostAre the MY08's different to the 09 ?'s The battery for the R36 is in the boot behind the panel that slides off in my Wagon ?Gone...........R36 Icelandic Gray Wagon
Specialising in off-topic discussion
You can alter this using Vagcom/VCDS to disarm the alarm when a key is used to unlock and/or arm the alarm when a key is used to lock. By default these are disabled.Originally posted by Swallowtail View PostNote too that if you have the VW car alarm fitted this will set it off... but pushing the remote into the ignition slot will de-activate it.website: www.my-gti.com
Hi Guys,
After 1 week of discussion with vw road assist. No luck.. they suggested to brick my window...
I was thinking to cut my sunroof rubber if possible.. since rubber is cheaper than window glass.
Any other ??
maybe cut my front grilll..??
thanks
origin
If you ever need to smash glass to get into your vehicle check availability and price before smashing. The front windscreen is often the best option as they are replaced far more frequently than any other (and so are more available and cheaper than the others)2017 MY18 Golf R 7.5 Wolfsburg wagon (boring white) delivered 21 Sep 2017, 2008 Octavia vRS wagon 2.0 TFSI 6M (bright yellow), 2006 T5 Transporter van 2.5 TDI 6M (gone but not forgotten).
in short, without being rude, no, the suggestion was for you to have a look.Originally posted by origin View PostHi Passatpout,
Could you possible to check where is the cable going exactly?
originMY08 Passat 2.0 TDI Wagon
I find it hard to believe that a car would be manufactured without a fail-safe for the door locks/electrics.
From the previous posts I assume that you have tried the plastic key as per the manual.
This kind of highlights that possibly VWAssist isnt all that good either
RichMY08 TDi 125KW Black Leather, Deep Black Pearl
