how to open door manually
    Originally posted by Rocket36 View Post
    add [ IMG ] to the front of any image link and [ / IMG ] to the end and it embeds it (without spaces though).
    Photobucket has this as an option ready to copy and paste for every image you upload.
    Yeah, that's what I tried (the [ img] and [ / img] without the spaces) and all it put in the post was the link.. I took the link from the address bar in Explorer. Will keep looking in Photobucket..
    MY08 Passat 2.0 TDI Wagon
    Trialling golf ball aerodynamics theory - random pattern, administered about 1550 on Christmas Day, 2011.
      Hi Rocket36 / passatpout,
      Thank you for your help and image..
      I did that but no luck.
      Did you unplug your car battery before you tried that?
      Thanks
      origin
        The link on it's own is: http://i624.photobucket.com/albums/t...g/DSC00268.jpg
        With the code: [ img ]http://i624.photobucket.com/albums/tt321/alpout/Passat%20Manual%20Unlocking/DSC00268.jpg[ /img ]
        With the code but without the spaces:
        Trust me - it works... It works for any image link on the internet!
          Thanks
          origin
          Nope, I left my battery connected.
          Might be time to call VW about it... it should still have roadside assistance available..
            Ah-hah.. thanks Rocket, all done now, I think I can work it out from here..
              Are the MY08's different to the 09 ?'s The battery for the R36 is in the boot behind the panel that slides off in my Wagon ?
                Same for MY09...
                Gone...........R36 Icelandic Gray Wagon
                Specialising in off-topic discussion
                  Originally posted by Swallowtail View Post
                  Note too that if you have the VW car alarm fitted this will set it off... but pushing the remote into the ignition slot will de-activate it.
                  You can alter this using Vagcom/VCDS to disarm the alarm when a key is used to unlock and/or arm the alarm when a key is used to lock. By default these are disabled.
                  website: www.my-gti.com
                    Hi Guys,
                    After 1 week of discussion with vw road assist. No luck.. they suggested to brick my window...
                    I was thinking to cut my sunroof rubber if possible.. since rubber is cheaper than window glass.
                    Any other ??
                    maybe cut my front grilll..??
                    thanks
                    origin
                      Is there a way to get under the bonnet and pull the cable from under/behind the bumper?
                        Hi Passatpout,
                        Could you possible to check where is the cable going exactly?
                        Thanks
                        origin
                        • #27
                          If you ever need to smash glass to get into your vehicle check availability and price before smashing. The front windscreen is often the best option as they are replaced far more frequently than any other (and so are more available and cheaper than the others)
                          • #28
                            Hi Passatpout,
                            Thanks
                            origin
                            in short, without being rude, no, the suggestion was for you to have a look.
                            • #29
                              I find it hard to believe that a car would be manufactured without a fail-safe for the door locks/electrics.
                              From the previous posts I assume that you have tried the plastic key as per the manual.
                              This kind of highlights that possibly VWAssist isnt all that good either
                              Rich
                              MY08 TDi 125KW Black Leather, Deep Black Pearl
                              • #30
                                errrrr... the steps with pictures above works perfectly. you must not be doing it right.
