Fiscon bluetooth question
  • #46
    Originally posted by cyberbob_au View Post
    Also - another annoying thing is that everytime my phone makes a noise, when browsing through the phone it mutes the stereo for a minimum of 10 seconds or so. The nokia just used to play the sound over the top of things.
    Yes- with the standard bluetooth and nokia i get the same thing. but i lost my nokia e61 and have replaced it with an iphone ( latest model with 16G- not sure what you call them). the wife still has a basic nokia and it does the 10 second mute thing.
    I can report that the iphone and standard bluetooth works REALLY well, sound quality wise . and it only grabs the car audio if you make a phone call in/out.
    As well, the iphone is really smart as you get a pop up on the phone: USE bluetooth ( the default if you dial or it rings) , or iphone - you can switch back and forward easily.
    i still reckon the $790 is steep- my new merc c-320cdi included a premium setup. ok ok -more $$ but many of you are comparing VW to merc & BMW. anywayit comes up with a full list of your contacts - you can store addresses+ numbers for each contact+ includes voice recognition. if only i can work out how to drive it.....
    had a passat tdi. now mb c class.
    • #47
      Ok, so the Fiscon is installed and all works well.
      ...However, I can not get the Radio back in the craddle to screw the 4 torx screws, it is like the loom / module are too bulky at the back and it does not slide back in.
      Did anyone else have this problem?
      How did you fix it?
      I have the Fison at the back and to the bottom, I can not find anywhere else to put it.
      • #48
        How did you fix it?
        Radio (Sat Nav) back in and mounted, all working as it should.
        There was no need to have VAGCOM to code it, plug and play.
        Bluetooth works really well!
        And the fact that I installed it myself, saved a lot of money!
        $995 fitted, I paid $300!
