Can any one help me.
I want to put a mobile (blue tooth) phone cradle to the left of the steering wheel and run a power supply to the phone from under the dash. I don't want to visually see the power cables in the cigarette/power socket at the front as I want it to look neat. I have read how I can pull the dash apart and tap into the rear of the front cigarette lighter but is there anywhere else I can get positve and negative feeds to the phone from under the dash without extensive removal of the dash.
. the supply point is probably off a 100A or similar fuse which if you blow that would likely take out a lot of the electrics
