Just wondering if any others are getting frustrated with the unpredictable functionality of the RNS510?
My main problem revolves around using the "mix" setting on the HDD. It works perfectly well while the car's running, but after turning off the car and re-starting it, it's pot luck as to what happens next. Logically you would assume that it would continue playing on mix as previously instructed, but rarely does this happen. A variety of events could occur, such as:
- Mix gets switched off and the songs in the last played folder are played in order
- Mix continues, but only in the last folder that was accessed
- The unit stalls on start-up and you have to switch to radio and then back to HDD to make it work, at which point a song is chosen randomly to be played.
- The unit boots up playing a CD (if one is inserted).
You never can tell what's going to happen. Are others experiencing the same issues?
Wyatt.
Wyatt.
