Hi all,
I'm planning a (epic) road trip from Perth to the Eastern states and back from mid/late July 2015 to mid August 2015 and would like to get some advice/feedback/input from fellow CC owner/drivers out East.
Will be in Sydney then off to Melb via Canberra at the start of August.
Was originally planning an overnight stop in Albury, but then a mate of mine suggested Thredbo as a stop over which sounds like a fantastic idea.
However, I've been looking into it and it would seem that my CC, being 2WD may not be suitable for the road conditions typically encountered in early August up in there in the alpine regions.
There also appears to be a regulatory requirement to carry snow chains which I initially thought shouldn't be an issue. However, when I looked into it further, it seems that it's not possible to fit snow chains to your CC and even if you could, expect the chains to cause paint damage in the wheel well due to insufficient clearance. From what I've gathered, the 4Motion V6 version of the CC is exempt from the requirement to carry chains, even though chains are still recommended.
As for the wheels on my CC, I opted to stick with the standard, factory Lakevilles and Continental "contiseal" tyre combo.
Has anyone taken their TDi CC into the alpine regions, specifically the 2WD TDi version? If you have, what preparation did you have to do?
Thanks in advance,
Cheers,
Eaglen00b
Thanks in advance,
Cheers,
Eaglen00b
