Pendulum Mount bushing - non factory
  • #16
    If you are in the Castle Hill area then take it to either Eurowerke or German Performance Garage to be fixed - both these places are in Castle Hill.
    B9 Audi SQ5
    • #17
      I had issues with Denlo Volkswagen servicing at Parramatta, switched to an independent pretty quickly.
      Parramatta Vehicle Services and Carbon Autohaus are another two great mechanics in your area I can vouch for.
      Exoticars also have a good reputation but I have not used them.
      • #18
        I'm in Liverpool area, there's Pacortech near by that i used for DSG service , they seemed knowledgeable and i have heard good things about them , i will contact them and see if they can fix this for me .
        Arteon 2018 ,white , Sound and Style Package , Sunroof, APR Stage 1,Turbo Inlet ,K&N
        • #19
          I believe it requires removing the subframe and then re-pressing the bushing/mount back in using a press.. I looked at replacing mine with uprated solid mounts from 034 and their web page explains some installation details - Dogbone Mount Pair, Street Density, Volkswagen & Audi MQB And MQB EVO .. I ended up going with the RacingLine (upper+lower) insert, as installation was simpler (cheaper).
          INSTALLATION:
          Installation of these mounts requires removal of the front subrame and the use of a press to remove and replace the dogbone mounts. For this reason, we recommend taking your vehicle to a reputable Audi/Volkswagen specialist for installation.
          FYI - having just an upper or lower insert can cause uneven force, resulting in a failed mount... that's why I asked earlier if you'd had a single insert at some point.
Name:	034-509-1035 Cut-Away.jpg
          Edit: as JustCruisn said, you'll want to replace all of the stretch bolts while the subframe is out. Also a good time to get an alignment/collar kit!
          2018 Arteon R-Line - Black, Sunroof, Dynaudio, 20" Wheels, RacingLine: Stage 2 ECU+DSG|380mm BBK|Intercooler+Hoses|Oil Cooler|R600 Intake|Adjustable Front Droplinks|Dogbone Insert|Subframe Brace+Alignment Kit|Propshaft Alignment Kit, Milltek: Zirotec Downpipe, Harding: Front+Rear Sway Bars|Rear Droplinks, Other: OSRAM Dynamic Indicators, EvcX Throttle Controller, 034 (RED) Coil Packs, Various Carbon Bits
          • #20
            I've done the mount on a MK5, it is the same design.
            The subframe comes out, onto the bench. Cut both top & bottom mounts out, press in the new ones.
            Lots of new bolts required. Then a wheel alignment.
            MK4 GTI - Sold
            MK5 Jetta Turbo - Sold
