It seems the R600 intake only uses one side of the grille for direct intake (same as stock). There's a piece of soft plastic/rubber blocking the vent on the passenger side.
Driver side with "scoop":
Passenger without "scoop" (plastic/rubber barrier hanging down a bit):
Does anyone know if it's possible to remove the plastic/rubber and add a 2nd vent/scoop? Not sure what else is under there, so might not be possible.
FWIW - I know it probably won't make any significant difference at the current performance levels (stage 1). I just want to know if it's possible for optimizing air flow later down the track.
