Arteon Map Updates
  • #31
    I just went through this process again, failed to locate the update on my Samsung 64gig sdcard in exfat, and also failed on a Verbatim 32gig.
    I tried a USB stick with no luck. Had to buy another Sandisk 32gig sdcard & that worked again first time.
    • #32
      What did you format the Verbatim 32gb one as and how big was the Stick
      Also note that you can only load 1000 tracks straight onto the internal SSD jukebox
      I thought I had 2000 and then noticed half hadnt loaded
      However if you put them on in 1000 amounts it will add to previous ones up to about 3000 max
      • #33
        I did both exfat & fat32 on the Samsung. Just exfat on Verbatim.
        USB was a 32gig Sandisk Force in exfat plugged into phone area socket, also no good.
        I easily spent 3 hours prepping the various data options & then it took a 40 minute drive to install when that last one worked.
        Looks like I will just stick with Sandisk SDcards for future updates.
        I managed to fill my SSD jukebox partition because I had aquired a large number of FLAC data files, with just mp3 it would be plenty of space. I also have some MKV with DTS-HD lossless audio encoding which work well, although I think I left those on the sdcard. I don;t think the amp supports positional audio though, just seems to be the stereo downconversion all around the car.
        • #34
          I managed to fill my SSD jukebox partition because I had aquired a large number of FLAC data files, with just mp3 it would be plenty of space. I also have some MKV with DTS-HD lossless audio encoding which work well, although I think I left those on the sdcard. I don;t think the amp supports positional audio though, just seems to be the stereo down conversion all around the car.
          Yes well Fat32 is the way to go and 32gb is any amount big enough and windows will format them properly at that size Just use default Fat32 settings
          Why so long mine downloaded in less than an hour chucked it in the car and 45 mins later it was done Just left car idling in garage.
          Anyway you can stop it and it will just start up from where it stopped no problem.
          Ive only got MP3's cos Im lazy and just get it all off the net and have ripped a few Cd's into it as well as I have enabled CD ripping in the car
          • #35
            I just use Spotify... no more downloading anything and no need for that jukebox really.
            My Car: 2019 Arteon
            • #36
              Yes very good but what do the backward people who only use a phone as a phone. I dont have any data allowance on mine and cant be bothered doing it at home via Wifi and all the mucking around.
              I have about 53Gb of music on my computer so just load some of that in every now and again for variety
              • #37
                2019/2020 Australian Maps
                Hi All, just updated maps to 2019/2020, just a couple of points of note. When I unzipped the file my directory didn't have the MD5 file which I believe is some kind of check sum. Anyway rather than downloading 23GB of data again I put the SD card into SD1 and 52 minutes later all was good.
                2017 Arteon Turmeric Yellow
                2014 Scirocco Viper Green
                • #38
                  [ATTACH=CONFIG]47770[/ATTACH]
                  Thats all it usually has
                  • #39
                    I was comparing my extracted files to the OP's image. Thought it might be relevant, especially since there seems to be a degree of difficulty in getting the unit to recognise media.
                    • #40
                      Hi guys probably a silly question to start with but did you ask your VW dealer to do this for you ? i did on my 1st service & they did for free. Next question does anyone know if you can & then if yes how to get your live google maps on to your dash ?
                      As soon as you go android auto the maps only appear on the info unit & not the dash.
                      • #41
                        No you get the maps off VW germany and No you cant have Google maps in the dash in front of you As far as most poster tell us
                        • #42
                          Hi All,
                          Spent days researching and downloading, trying failing. Finally I got it to work!
                          Nav device: Discover Navigation Pro
                          Download: http://vw-mapscdn.tdd.adacordcdn.com...S5MIBH3_ROW.7z (2020 maps 24.2GB)
                          Media device: Lexar Jumpdrive v100 USB 3.0 32GB (Bought from Woolworths)
                          Copy method: FAT 32 format. Unzip files (not parent folder) into USB
                          Patch method:
                          1) Plug into USB port located inside mobile phone compartment.
                          2) Go to navigation > settings > version information
                          3) Tap "Update (SD/USB)" <--(this is where I got stuck most of the time)
                          4) After a few seconds to a minute, an update on the USB should be detected. Accept update and update should take 40 mins approx.
                          What failed for me in previous attempts:
                          - Sandisk 32GB 98mb/s in both exFat and Fat32 formats
                          - Lexar USB 3 32GB, with ExFat format (the same USB device as above)
                          • #43
                            Originally posted by Eded View Post
                            Hi All,
                            Patch method:
                            Cant understand why people have so much trouble
                            I have latest on a 4year old well used Samsung 32GB microSD card I had in my dashcams Formatted in Fat32 and not a single problem
                            Have another copy on an old Fujitsu 32Gb SD card also formatted as Fat32 which also works
                            Stick either in one of the SD slots in glovebox and it finds it and updates Simples
                            Your link doesnt work for me
                            • #44
                              Hi @Hillbilly
                              My bad here is the link:
                              Regarding why the MicroSD didn't work, I wish I knew why. It could be one of the following reasons:
                              a) The brand and specs of the card weren't compatible (Sandisk MicroSDHC 32GB UHS-I card with adapter)
                              b) The adapter was defective
                              c) The card itself was defective
                              d) The SD card reader in my car was defective
                              e) Software or firmware within the SD reader or infotainment selectively only allowing VW SDcards write access.
                              f) The files were corrupted or did not copy over properly
                              g) The SD card was formatted in Fat32 in OSX Apple Mac.
                              b, c, d and g are unlikely because I was able to see the files while browsing in the infotainment's photo viewer. Though with g) not sure if OSX Fat32 is different to Win Fat32, or if it matters.
                              Im not sure why e) would be the case since USBs would then be too easy of a backdoor.
                              That would then leave a) or f) or possibly g)
                              • #45
                                Hi @Hillbilly
                                B or D is most likely but you have two SD slots dont you
                                Yes using a fruity think is different and causes more problems than enough
