Arteon VCDS / OBDEleven Tweaks - Confirmed working
2018 Arteon R-Line - Black, Sunroof, Dynaudio, 20" Wheels, RacingLine: Stage 2 ECU+DSG|380mm BBK|Intercooler+Hoses|Oil Cooler|R600 Intake|Adjustable Front Droplinks|Dogbone Insert|Subframe Brace+Alignment Kit|Propshaft Alignment Kit, Milltek: Zirotec Downpipe, Harding: Front+Rear Sway Bars|Rear Droplinks, Other: OSRAM Dynamic Indicators, EvcX Throttle Controller, 034 (RED) Coil Packs, Various Carbon Bits
Was that the change to audi, if so can you share how you did it in obdeleven
Coding
Do you remember the coding trying to do it on my22 with no luck.Originally posted by david86 View PostHad just activated traffic sign recognition... doesn't work as well as expected in Melbourne metro I.e. road sign detection only mode ignores map data so it holds the 80kmph when turning to a 50kmph side street. Is there any way around to get the system to fall back on map data?
Top row is BYTES columns are BITSOriginally posted by neveo71 View PostCan you tell me how to do the audi setting I don't really understand how to change long coding as I don't understand the layout. Ie is the top line the byte but then under it it says byte ect2021 Kamiq LE 110 , Moon White, BV cameras F & B
