OEM Tiguan Clutch Replacement
  • OEM Tiguan Clutch Replacement
    Have seen a few contradictory threads on this on vwwatercooled and vwvortex so i thought i'd pose the question here, again. Can anyone confirm that the Audi TTRS Clutch can be used as a replacement in a 132TSI 6Speed Manual Tiguan without ANY modification? I have a Stage 1 Tiggy and I think it'd be appropriate to change the clutch to something more heavy duty if possible since I need to replace the clutch anyway.
    Anyone know?
      I'm assuming whatever fits a MK6 Golf GTI, will also fit this.
      '07 Transporter 1.9 TDI
      '01 Beetle 2.0
        No actually, its a completely different gearbox. Same one as in the Audi TTRS!
          Clutch generally has more to do with the flywheel/engine fitted than the gearbox itself. Chances of a TTRS one fitting are slim to none?
          Volks Handy
            The TTRS clutch is sold by HS Tuning in USA and fits the Mk6 R, Mk5 GTI and Mk6 GTI - although it does not mention the Tiguan. Might be best to shoot them an email or give them a call to ask.
            HS Tuning RSR 2.0T Clutch Kit - HSTRSR1
            For a stock or even a stage 1/stage 2 Tiguan i would suggest the heavy duty version of the OEM Sachs clutch would do just fine. https://www.sachsperformance.com/en/...-4motion-132kw
            B9 Audi SQ5
              approx cost of one of these OEM Sachs clutches in oz ?? what should we expect to pay? or should it be ordered from this site in the UK?
              2019 Golf R | 2024 Tiguan 162TSI | 2007 Golf GTI | 2007 Eos 147TSI
              2001 Beetle SR | 1976 VW Beetle - BE
              2018 Tiguan 162TSI[Sold] | 2016 Skoda Octavia RS[RIP] | 2011 Tiguan 125TSI [RIP] | 2001 Golf GTI [Sold]
              2000 Beetle 2.0 [Sold] | + Various old Beetles (1971, 1972, 1974, 1975)
                Have just fitted Racechip pro 2 to Tiguan 132 TSI 6 speed manual. Very good power increase...........too good because the power completely overcomes the clutch at about 3000rpm in the higher gears.
                I'm thinking that perhaps I'd better unplug it or serious damage will occur, or fit a stronger clutch. I'll be glad to hear of a suitable solution because i really like the extra grunt. That SACHS clutch looks ok, but I wonder how many hours for fitting.
                  Update. Solution from Racechip was to dial chip down a notch. Clutch is coping now.
                    Had Sachs performance clutch and actuator fitted......Full power, not even thinking about slipping.
                    Pedal is quite a bit heavier and uptake crisper as I expected. No noises and I'm happy with overall result.
                    Tiggy is now a real wolf in sheep's clothing.
                      Old thread but what was the approx cost of doing this. I have the same problem.
                        I ordered the clutch and actuator from Sachs in Germany and that was about $1200au at the time. The guy that fitted it was a wizard because it was not easy, and he only charged me $800 I think. The good part is that the performance clutch is coping easily and the pedal pressure is a little lighter than it was initially. I have only done 10,000kms with the Racechip, it still performs well and has not pooped itself.
                        My advice is to find a really good VW person that knows what they are doing to be sure of a good job.--------Good luck !
