Did another scan and now more things came up:
6 Faults Found:
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 70985 km
Time Indication: 0
Date: 2015.08.13
Time: 17:35:06
Freeze Frame:
RPM: 4058 /min
Load: 100.0 %
Speed: 72.0 km/h
Temperature: 97.0∞C
Temperature: 24.0∞C
Absolute Pres.: 1010.0 mbar
Voltage: 13.335 V
000290 - Throttle Position Sensor (G69)
P0122 - 000 - Signal too Low - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 72321 km
Time Indication: 0
Date: 2015.09.26
Time: 14:43:47
Freeze Frame:
RPM: 762 /min
Load: 31.0 %
Speed: 0.0 km/h
Temperature: 98.0∞C
Temperature: 68.0∞C
Absolute Pres.: 1020.0 mbar
Voltage: 13.208 V
000546 - Angle Sensor 2 for Throttle (G18
P0222 - 000 - Signal Too Low - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 72321 km
Time Indication: 0
Date: 2015.09.26
Time: 14:43:47
Freeze Frame:
RPM: 762 /min
Load: 31.0 %
Speed: 0.0 km/h
Temperature: 98.0∞C
Temperature: 68.0∞C
Voltage: 13.208 V
005464 - Throttle Actuator (G186)
P1558 - 000 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 72322 km
Time Indication: 0
Date: 2015.09.27
Time: 10:15:29
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 255.0 km/h
Temperature: 11.0∞C
Temperature: 16.0∞C
Voltage: 11.938 V
008487 - Accelerator Position Sensor 2 (G185)
P2127 - 000 - Signal too Low - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 72322 km
Time Indication: 0
Date: 2015.09.27
Time: 10:43:17
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 48.0∞C
Temperature: 19.0∞C
Voltage: 11.938 V
008482 - Accelerator Position Sensor (G79)
P2122 - 000 - Signal too Low - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 72322 km
Time Indication: 0
Date: 2015.09.27
Time: 10:43:17
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 48.0∞C
Temperature: 19.0∞C
Voltage: 11.938 V
Readiness: 0000 0101
6 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 70985 km
Time Indication: 0
Date: 2015.08.13
Time: 17:35:06
Freeze Frame:
RPM: 4058 /min
Load: 100.0 %
Speed: 72.0 km/h
Temperature: 97.0∞C
Temperature: 24.0∞C
Voltage: 13.335 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 72321 km
Time Indication: 0
Date: 2015.09.26
Time: 14:43:47
Freeze Frame:
RPM: 762 /min
Load: 31.0 %
Speed: 0.0 km/h
Temperature: 98.0∞C
Temperature: 68.0∞C
Voltage: 13.208 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 72321 km
Time Indication: 0
Date: 2015.09.26
Time: 14:43:47
Freeze Frame:
RPM: 762 /min
Load: 31.0 %
Speed: 0.0 km/h
Temperature: 98.0∞C
Temperature: 68.0∞C
Voltage: 13.208 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 72322 km
Time Indication: 0
Date: 2015.09.27
Time: 10:15:29
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 255.0 km/h
Temperature: 11.0∞C
Temperature: 16.0∞C
Voltage: 11.938 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 72322 km
Time Indication: 0
Date: 2015.09.27
Time: 10:43:17
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 48.0∞C
Temperature: 19.0∞C
Voltage: 11.938 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 72322 km
Time Indication: 0
Date: 2015.09.27
Time: 10:43:17
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 48.0∞C
Temperature: 19.0∞C
Voltage: 11.938 V
