G-8VXWWTRHPN pre-facelift 147TSI Tiguan Fuse box diagram - VWWatercooled Australia
This topic is closed.
  • pre-facelift 147TSI Tiguan Fuse box diagram
    Hi guys,
    I need a fuse diagram for a pre-facelift 147TSI Tiguan and can't find it on the net. Can anyone point me in the right direction?
    Which fuse are you trying to find?
    Much of it is the same as the Mk6 Golf. If you can find something for that then this may give you a clue.
    - Tigger73's 125TSI Build
      Okay so a bit embarrassing, I have a remote wire for an amp in one of the fuses and starting having issues last night with the bit ten and therefore amp not switching on.
      At first i thought it may have been the remote so I pulled the fuse to check the connection, got distracted and then forgot which socket it came out of, so really just making sure I put it back in the right slot. I'll take a photo tonight and post it up to see if anyone can help. It doesnt seemed to have affected anything that I can tell so not even sure what its for.
        All good, figured out which slot it was meant to go in and also the issue I was having with my amp was a loose earth wire.
