Tiguan fuel line rattling
  • Tiguan fuel line rattling
    Last few weeks I had a big headache with my Tig because of very annoying rattling noise coming from driver side door. It seamed to be getting progressively louder and worst, mostly arround 2200 RPM to 2600 RPM just when gear changes happening on sports mode. Rattling sound is like very high frequency vibrating noise which last for few seconds untill I stay in that RPM band. I had very hard time figuring out where it is coming from because it looked like coming from every where , from driver side door , side pillar, driver side pasenger door, from dash, even from roof. Lol.
    Also I could reproduced similer kind of rattle but with low frequency vibration, when car is idling and increase engine speed up around 1100 RPM. So I thought both rattles should somehow connected with each other and asked my wife to keep the engine on 1100 RPM and put my ear everywhere possibe to find the exact position of the source. Then finally I found it! It was coming from the floor just behind the driver seat. After that it was quite easy since I know the approximate location of the rattle and goole search of "VW rattling under floor" pinpointed the problem as it is infamous fuel line rattle.
    Solution.. take the underbody plastic panel out and press some softform through the elliptical hole to keep fuel line from vibrating. Viola! Now no more nasty rattles and I can enjoy sports mode agin
    some pics ..
    Under body plastic cover removed
    Fuel lines go through this channel caused the rattle
    Elliptical hole used to pressed soft foam in.
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Nice one Ramee.
    Do you want to come over to my place as I have an annoying glove box rattle that needs fixing
    - Tigger73's 125TSI Build
      Thought it was only the South African built VW's that develop rattles...
