Tiguan 155 Acceleration
  • Tiguan 155 Acceleration
    I've recently aquired one of those Auto Polar boxes and I thought I would time my 0-100 sprints. I set the start point to 0km/h and end to 100km/h on the chronometer, select start, engage LC and go for it.
    My car is a 155 Tig w 7spDSG (stock), 3/4 tank of 98 fuel and I weigh about 95kgs, outside temp was around 17c.
    The highest time I recorded was 6.52 0-100, the best I got was 6.45. Of course I used Launch Control. Without LC I get 7.3 which is the factory claimed figure. Either I have a little more power on tap for some reason or the factory figures are without LC?? I would have thought VW would be using LC for their "claimed" figures.
    I know there can be variations in real world figures, but I would have thought VW would publish the absolute best they could...
    What sort of figures does everyone else get? Or is there sometimes a deviation in what the AutoPolar records?
    I did notice that my auto polar shows around 95km/h when my spedo is on 100km/h. I'm guessing the Auto polar is true speed...
    Also, are there any tuned out there w DSG's that know their 0-100 times?
    MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
    MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
    yeh your speedo is allowed to be 10% +4kph over the actual speed but can not read under by anything. ADR regulations..VDUB..
    BRISBANE / GOLD COAST
      I haven't done any LC runs but my Tig currently does 0-100 in around 7secs. However I'm waiting on a new tune file before I do any LC runs and I reckon I'll be in the low 6's or high 5's then.
      I actually think VW is conservative with their 0-100 times (so that it's guaranteed that people can achieve it).
      Plus they're not marketing their cars as performance vehicles and if they publish more agressive times, they may send the wrong message. After all these are figures in the marketing brochures that we're talking about (they can pretty much put anything in there that they like).
      Regarding autopolar speed indication, this is the actual uncorrected speed read direct from the ECU (before they put the fudge factor on to display). I have checked the autopolar speed against highway speed checks and it is right on. So as long as you're running standard tyre sizes, your 0-100 times are going to be pretty accurate from the auto-polar.
      And as far as repeatability I've got 0.01sec difference running on exactly the same strip, same conditions doing a foot to the floor test (which I think is more repeatable than using LC). So definitely have managed to get good repeatability.
      Though what I haven't done is run the autopolar against a more accurate/standard/calibrated device. So this would be the acid test however given speed reading is accurate, I have no reason to doubt the 0-100 times the autopolar are putting out are pretty much spot on.
      I now set my cruise control off the autopolar speed as I trust this more than the speedo (my speedo is about 6km/hr out at 110km/h).
      - Tigger73's 125TSI Build
        That's odd Tigger73. I would have thought you'd be a lot quicker than me given that you have a tune with all those bits and I don't. Or is that with a stock calibration?
          6.5 is nice & fun
          Were the tyres warm? Makes a difference for me (but I'm FWD )
          The published times for my car are for the hatchback (where as I have the wagon) and were done using EU 100 octane fuel/tune
          Skoda create one marketing blurb to be used worldwide
            At the moment Viezu only has a Performance level tune for the Tig/Mk6 GTI. This is probably only a marginal improvement over the stock 155, though is a reasonable step up from the 125/132.
            The Viezu techs are working on a Race level tune. As soon as I can get my car retuned with this I'll run some new numbers, then my car will run a lot quicker than it currently does.
            In reality as far as the performance stakes goes I only have a tune + DP - the CAI will make a couple of kW at best and the FMIC is mainly for maintaining the performance over repeated runs or in warmer weather. All the other "stuff" is either cosmetic upgrades / additional non-performance features or handling upgrades so not really going to contribute to 0-100 times - probably go the other way as it's all extra weight
              For what its worth Stg1 APR Tiguan manual will do 0-100 in 5.7s and Stg2 0.1-0.2s quicker than that. Stg1 quartermile in 14.0s which is quick for such a heavy car with only 190kw/400NM ...... another 2 tenths probably in it for Stg2 ....
                For what its worth Stg1 APR Tiguan manual will do 0-100 in 5.7s and Stg2 0.1-0.2s quicker than that. Stg1 quartermile in 14.0s which is quuick for such a heavy car with only 190kw/400NM ...... another 2 thenths probably in it for Stg2 ....
                Cool. I wonder how much better/worse the DSG would do.
                  With launch control it will be a bit quicker and without launch control a bit slower .....
                    DSG with launch control is almost always going to be quicker. No matter how quick you are with the manual you can't beat having the gear pre-engaged ready to change from one clutch to the other in a DSG.
                    That's why nearly everyone putting a VW to go down the strip these days chooses a DSG forthe tranmission just because it's quicker to launch.
                    Manual box for the purists of course!
                      How you guys measure the 0 -100 time ?
                      This is what I got with android torque app.
                      Both cases 155KW Tiguan , DSG , Launch control On , 98 oct , Cold evening about 14 deg
                      Best Stock 0 - 100 time
                      With APR Stage 1 , 0 - 100 time (Just flash, no intake or any other mods)
                      2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
                        A few of us have the AutoPolar FIS+ - for details see link here: http://www.vwwatercooled.com/forums/...ide-80439.html
                        I know a few people have used various phone apps. Nice thing with yours is how you've built it in. I think people are concerned with leaving a phone on "display" in the car in case someone breaks in.
                          Originally posted by tigger73 View Post
                          A few of us have the AutoPolar FIS+ .
                          AutoPolar FIS unit seams to be nice a gadget. I wonder how accurate 0 100 time of these various methods of monitoring performance..What could be the best way to get a proper 0 100 time ? Or it will be good if we can calibrate these things with a reference
                            The autopolar takes the uncorrected speed from the ECU so this should be pretty accurate. As long as you're not running non-standard tyre sizes it should be pretty close - but obviously isn't calibrated.
                            There's a few variables like how quickly/often the device is getting updates on the speed measurement and how accurate the timer is as well as the actual speed measurement of course. I reckon these OBD port speedo/timers are probably good for 0.1s accuracy depending on the polling interval.
                            It would be interesting to run them against a v-box or a "calibrated" timing device to see what the variance is.
                              Hey Ramee, did you have to have your ECU bench tuned for the APR STG1?
