2012 Tiguan 155tsi transmission issues
  • #31
    Originally posted by DoggieHowser View Post
    Maybe if there's a tweak for the steering response. I read that there's one for the Polo.
    The Tigger doesn't feel as rewarding to drive because the steering feels uncommunicative. The Golf based chassis is great and with Adaptive Chassis Control, a very car like response to boot.
    But as is, it doesn't inspire me to modify it.
    Eibach Pro-Kit Springs and Poly Lower A-Arm bushes make a world of difference IMO. Ride is still reasonably comfortable, but handling much better and steering more pointy and responsive! Only down side is that is also makes the low speed steering rack rattle over bumps more noticeable.
    I originally got the springs to try and tune out some of the "jitteriness" of the original ride, but the difference to sporty feel is amazing
    2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
    • #32
      Originally posted by gecko2k View Post
      Awesome! And of course we can wait, that's what you do when you own a Tiguan
      It won't be this week No time frame given to me yet.
      • #33
        Fingers crossed you have it next time you're in Adelaide....
        - Tigger73's 125TSI Build
        • #34
          Actually I think the Adaptive Chassis option is well worth the money.
          But that doesn't fix the very light steering feel which doesn't give much feedback.
          • #35
            Another compromise for fuel efficiency (ie. electro-mechanical). I don't mind it myself, and definitely more roadfeel with poly bushes. I believe the bushes also change the caster slightly which gives "harder" (but more direct) steering.
            • #36
              Another compromise for fuel efficiency (ie. electro-hydraulic). I don't mind it myself, and definitely more roadfeel with poly bushes. I believe the bushes also change the caster slightly which gives "harder" (but more direct) steering.
              Have you noticed any difference in tyre wear rates?
              Just wondering how many km's people get out of a set of tyres and if changing the suspension is going to have an adverse effect.
              • #37
                Doesn't matter much to me, as long as it's coming at some point!
                • #38
                  Hi. One of those "how long is a piece of string" type questions I think - depends on tyre/road conditions/climate/driving style etc, etc. In my case, on Bridgestone Dueler H/P 235/50R18's, on variety of road surfaces with even mix of around town, highway and range work, having travelled 18000km from new, I have 5.25mm tyre depth remaining to wear indicators. Seems pretty even all around with no excessive scrubbing on inside or outside of tyres (front or rear). I'd describe driving style as "spirited" in general (especially on ranges where more fun), but not on the limit always (occasional squeal but not sideways or anything). My personal opinion is that the suspension mod would improve overall tyre life (depending on driving style) as it lowers to C of G and therefore the car sits flatter and spreads the load more evenly over all 4 tyres ?!
                  I had the mods done about 4000km ago and have certainly not noticed any unusual or excessive wear.
                  Hope this helps.
                  P.S: apologies to Dani for hijacking thread
                  • #39
                    Yeah had thought the same thing too.... back to DSG tuning now
                    • #40
                      after driving my 132 dsg for 2 weeks i feel the same issue. you have to absolutely floor the thing to get the boost while S gear is responsive but it over revs like crazy on avg 60kmph speed streets. sigh...would an apr tune fix the issue? was thinking of putting it off after i get the sat nav done.
                      MY12 132TSI Tiguan Titanium Beige| DSG | Tint | Park Assist | RNS510 | Bi-Xenon |Comfort pack | R pedals | 155 Chrome Bits
                      • #41
                        Sorry an ECU remap won't do too much for the way the DSG selects the gears. You may pick up some lower end torque/power which will help it pick up better at lower revs but that is about it.
                        What you really need is a DSG tune.
                        At the moment only APR do these and they will set you back around $1200 - see Harding Performance for full details. Some of the other tuners do DSG tunes but not for DQ500 7 speed DSG gearbox in Tigs (yet). One of the things you've then got to worry about is that you've modified your DSG gearbox from manufacturers standard so all bets are off with respect to warranty.... and DSG gearboxes are not cheap things to repair.
                        So the other option that a number of people (including myself) have done is to buy/install a flappy paddle steering wheel. See this thread for all the details - http://www.vwwatercooled.org.au/foru...uan-56968.html.
                        Advantage of this is that it's a standard VW product available in Golf (plus in other countries is available in Tiguan) so "shouldn't" void warranty. You can then run around in manual mode and change gears from the steering wheel. This allows you to get around all the deficiencies in either D or S mode. Or if you do drive around in either of these modes to manually over-ride where required (down shift to first gear at low speed in "D" / up shift before 4,000rpm in "S").
                        And I completely understand your frustration at having shelled out a fair sum of money only to need to spend more to "fix" what "should" have been done in the factory.
                        I'll get off my box now.
                        • #42
                          thanks for the great info again tigger73. looks like a giant pain to do that mod, guess i'll wait for a DSG remap if there ever comes 1 from VW.
                          • #43
                            Don't expect VW to come out with anything any time soon. The DSG programming has been set up for best fuel economy in "D" and go hard performance in "S". Unfortunately there's no happy medium in either mode and can't see the changing this either. I don't think they would spend engineering time on the product unless there was some sort of safety issue.
                            Given that they had the chance to tweak the DSG in the mid-life face lift I seriously doubt it's on the list of anything that they're going to do. So either you live with it how it is or, once you're happy there's not gonig to be warranty issues, look to make some modifications to the VW original equipment.
                            I used to run around in "S" and hit cruise control when I got up to speed (to stop the annoying revving before the DSG finally decides to up-shift). This is OK if you're in light traffic.
                            But now I use the gearbox in manual mode and change gears with the paddles - which kind of half defeats the purpose of going with an automatic car.
                            If I'm out with the family I'll often just run in "D". If I need to I can always over-ride with the paddles which I will do when coasting downhill to stop going over-speed or if I'm overtaking.
                            • #44
                              Good News for 2012 Tiguan Owners Down Under
                              My 2012 Tiguan Pacific 132TSI 6 speed auto has this problem. After being told by the dealer, Pickerings Volkswagen Townsville, that my Tiguan drives to specification and finding that software fixes were available in Canada and the US, I sent the following to Volkswagen Group Australia via their website.
                              "I purchased a 2012 Tiguan Pacific 132TSI in June ( just clocked up 5,000 km) and I am extremely happy with the vehicle with one exception. The 6 speed auto transmission mapping has obviously been done with fuel consumption as the priority. This means my Tiguan wants to be in 6th gear at under 60 kph at approximately 1,000 rpm and gentle acceleration (which is necessary in city traffic conditions) results in lag, lugging and vibration. The resulting sounds are quite disconcerting for rear seat passengers. If the same thing happened in a manual you would change to a lower gear.
                              I find I have to drive in Tiptronic mode and keep the revs above about 1,700 for acceptable performance (ie 4th gear @ 60 kph, 5th @ 80 and 6th @ around 100kph). My wife "doesn't do Tiptronic" and asks why VW can make the Tiguan such a quality vehicle but cannot make it drive like any other auto transmission.
                              I see that VW in the US has issued software update to the Transmission Control Module. The Tech Bulletin number is: 1-12-13, the transaction number on the bulletin is 2029206. The description is of the bulletin is: Slight hesitation and or driving noise at low speeds in high gear.
                              Is this or it's equivalent available in Australia? And if not why not? I am not worried about fuel consumption, I just want my Tiguan to be driveable in auto mode in city traffic."
                              I received an email from Volkswagen Group Australia a week later saying a case advisor would contact me. Two days later the VGA case advisor called to inform me she contacted Pickerings to arrange to have the transmission mapping checked on my vehicle.
                              After testing, I was informed at a meeting with the Service Advisor and Pickerings Volkswagen General Manager that the transmission was “normal” for my Tiguan Pacific and they gave me a printout explaining how the electronic control used fuzzy logic to match shifting to throttle operation and driving conditions. My first thought was that Pickerings VW would just maintain the corporate line and would not attempt to fix my problem. However, after listening to my concerns, the GM did not argue but agreed to try and find a software fix.
                              Less than 24 hours later, the VGA case advisor called to inform me that there was a software update available and not long after Pickerings Volkswagen phoned me to schedule a time for my Tiguan to have the fix done.
                              I have been extremely impressed with the customer service and prompt action I have received from everyone I have dealt with at Pickerings Volkswagen, Townsville and Volkswagen Group Australia.
                              I will report back with my impressions after the new mapping is done.
                              • #45
                                Great. So the auto which nobody much complains about gets an upgrade but the DSG which everyone complains about doesn't. Go figure.
                                I guess they leave it to the tuning companies to refine the product....
